Rear mount turbo 3vze finished
#82
http://www.ebay.com/itm/NEW-Electric-Oil-Scavenge-Pump-for-Remote-Low-Rear-Mount-Turbo-Return-Line-12v-/280782665954?pt=Vintage_Car_Truck_Parts_Accessories&hash=item415ff378e2&vxp=mtr
Works well, a little noisy, but nature of the beast...
Methanol works very very well for fueling actually. I'm spraying 22gph from 2 nozzles at 14lb boost. AFRs are high 11s and touch on 12.1 at redline. Stock EVERYTHING. I'm using a very nice and expensive progressive controller with 2 failsafes. You could use a cheap universal kit, a 14gph nozzle on a 1psi hobbs switch. You can set your methanol tank up with a float switch, so when it's low you can trigger a http://www.ebay.com/itm/MAC-Boost-solenoid-valve-BCS-35A-AAA-DDBA-1BA-compatible-with-most-ECUs-EMS-PWM-/331006948808?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d118d35c8&vxp=mtr to cut to wastegate spring pressure. That's how mine is set up and I have a 2lb wastegate spring so when I'm out of meth, or somethign goes wrong, boost cuts to 2psi instantly, thus saving motor.
#83
hey, to the OP, I know I'm late to this party, but I have a solution to your closed loop enrichment problem.
https://splitsec.com/product/lsc1-00...chment-module/
I can't admit as to how I know this, but I know a guy using it and it works fantastic. And the owner of Split Second will walk ya thru the install. he will also give you wiring diagrams and help your install. Super simple, cut the signal wire of the o2 sensors and put in the enricher.
I real quickly show how I used it in this thread:
http://www.tundrasolutions.com/forum...l-tune-thread/
jon.r
07-11-2015 03:34 PM
skoti89
07-08-2015 12:05 AM
