Rear End issue?? Jerks while backing up Spool Rear
Old 08-05-2009, 11:26 PM
TrevanO's Avatar
Exclamation Rear End issue?? Jerks while backing up Spool Rear
This morning I got into my truck and while the truck was cold started to back up and noticed it being stubborn and resilent to back up, rear end shaking and a pulling feeling like it didnt want to back up. I put my head down and looked at the rear end while backing up and noticed the rear end vibrates and truck tends to shake. I have a full spool in the rear but it just started doing this
Old 08-05-2009, 11:30 PM
TrevanO's Avatar
Also i might add it just started doing this
Old 08-05-2009, 11:45 PM
fireman1559's Avatar
are you sure its not the tranny thats shakin
Old 08-06-2009, 12:15 AM
NicCantDecide's Avatar
this happens with my lockright when making low speed tight turns sometimes. I'm pretty sure its just my motor/tranny mounts being worn out. I assume its because the engine doesn't have enough power to break the inside tire free and instead it twists the engine/tranny.
Old 08-06-2009, 10:14 AM
TrevanO's Avatar
great
Old 08-06-2009, 12:22 PM
TrevanO's Avatar
can i just tighten the mounts ? think that would fix it?
Old 08-06-2009, 12:24 PM
904_runner's Avatar
probably not..
if your mounts are shot to the point of not doing their job its time to replace them. $.02
Old 08-06-2009, 12:33 PM
TrevanO's Avatar
which mounts are we talking about? the case mounts or the drive shaft mount to the 3rd
Old 08-06-2009, 12:39 PM
904_runner's Avatar
i would check every mount you have.. I don't know if the mounts are even the problem. But give them a good look over, grease your drivlines/ujoints and see if you find anything/
Old 08-06-2009, 01:22 PM
If its lugging like its binding/unbinding then its probably motor/tranny mounts.
If its vibration, could be the driveshaft, but it would do the same going forward also.
Old 08-07-2009, 11:16 AM
TrevanO's Avatar
yeah it only does it in reverse at low rpms, so tighten down the motor mounts and tranny mounts?
Old 08-07-2009, 12:04 PM
You can't tighten down the motor or tranny mounts, they're two plates with rubber in the middle. Once they start to tear there's no fixing them.
Old 08-07-2009, 10:24 PM
TrevanO's Avatar
niccantdecide theres no rubber inbetween the plates, i have 1 bolt right now holding the plates together, pretty sure if i bought 4 more bolts i might have a chance of fixing the problem
Old 08-08-2009, 07:55 AM
Jay351's Avatar
Replace the mounts, its not like they are that expensive...
stagger_lee
03-29-2016 06:27 PM
red88toy
11
08-03-2015 07:47 PM
bigblue82
10
07-06-2015 08:27 AM
merc1100sc
06-26-2015 05:24 PM
Eagle564
06-23-2015 11:29 PM
Quick Reply: Rear End issue?? Jerks while backing up Spool Rear
