rear bump stops for zuk mod, don't have them!
Old 07-05-2015, 08:25 PM
icentropy's Avatar
Hi all, I want to do the zuk mod but don't have the lower rear bump stops on my truck. Does anyone know what the PN is for them or where i can get them?
Thanks in advance.
Old 07-05-2015, 11:48 PM
wyoming9's Avatar
Red face
Last I looked at the dealer I priced them a few years ago I think they were around $50.00 each.
Find some used ones .
Old 07-06-2015, 11:01 AM
icentropy's Avatar
Thanks for the info. Good to know. My problem is I live about 3+ hours from the nearest decent parts yard (pretty rural over here) so I need to find them online somehow. I did find these on ebay http://www.ebay.com/itm/150350784590 they look the same as the pics of the ones i've seen online but they're for the front axle of the pre-86 trucks. Any chance you might know if they're the same?
Old 07-06-2015, 12:29 PM
wyoming9's Avatar
Red face
They look the same from the picture .
I bought quite a few things off of Bruce over the years good guy to deal with.
Where are you from??
Old 07-06-2015, 12:34 PM
icentropy's Avatar
okanogan highlands in central washington. I PMed the seller to ask if they knew if they were the same as used on the rear in 86-trucks, he replied with a "nope they're different".....bummer.
Old 07-06-2015, 12:44 PM
wyoming9's Avatar
Red face
I might have a set off my parts truck
I am just not sure if they are any good
They have a tendency to dry rot and break off.
I will look.
Old 07-06-2015, 01:11 PM
icentropy's Avatar
I will look.
Thanks, I'd really appreciate it. Even if the rubber is messed up I could use the metal base and attach one of the aftermarket bump stops that are available everywhere like these (http://www.ebay.com/itm/141286165207) Just need them to hold the bottom of the spring in place though.
Old 07-09-2015, 03:13 PM
peabody's Avatar
Zuk mod is great but my factory pressed bumps snapped off so you are headed in the right direction. Have plates too if Wyoming can't help.
Old 07-09-2015, 05:32 PM
icentropy's Avatar
Hi Peabody, Wyoming looked buy couldn't find his. Do you have the base plates for the bumpstops? If so I'll buy them from you.
Old 07-11-2015, 04:08 AM
peabody's Avatar
I have an extra set from parts truck. PM with zip/address; I'll send image, etc. Will want to see what you do with them.
Old 07-11-2015, 07:21 AM
icentropy's Avatar
Thanks Peabody! Much appreciated. PM sent. If the rubber is in decent shape i just plan on leaving them as is for the zuk mod. If the rubber is gone or cracked I will either buy one of those aftermarket bump stop sets and install them on the metal bracket or machine some aluminum cylinders that i can moutn straight to the brackets that have the same OD as the spring's ID. Just depends on if i have the material handy.I'll definitely post up pics either way.
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: rear bump stops for zuk mod, don't have them!
