radio problem...help
ok so the other day my radio started cutting out on me....the screen stayed on and i could use all the functions just no sound...i have an aftermarket stereo and it and off with every bump i make...its annoying...my truck is sitting in the driveway right now with the dash out...hopfully you guys can help...thanks
Location: Yotatech, because Pirate is too expensive. NorCal.
What brand is it? I would guess that it is just broken internally from large hits like coming down real hard on the suspention. If you smack it on the side when it is not working does it turn back on? If so, something probly got diconnected inside. If it is still under warranty you can call the manufacturer. I would call even if it wasnt.
Most likely 's one of your speakers or the wires going to them. If any of the speaker wires get grounded it will shut the audio portion of your deck off but the stereo will stay on. Check the wires from the deck to the speaker and look for any bare spots that could be grounding out.
Yes, good point. Alot of times people will wire them by just wrapping Electrical tape around the wires or they will use wire nuts, used for wiring a house.
They should have a very good crimp connection or be soldered together.
kawazx636
10-06-2021 03:03 PM
mct75
08-22-2016 01:24 PM
zombie_barbarossa
10-02-2015 10:54 PM
tazman1972
11
09-28-2015 10:32 PM
