Quick question about seafoam
Old 12-06-2009, 10:57 AM
nick1990's Avatar
WIll seafoam cause an oil leak leak more???.....because i have a small oil leak and i fixed that with a little lucas, it was nothing really major
Thanks
Old 12-06-2009, 11:00 AM
cgeorge's Avatar
Where are you going to add it? In the gas tank - no issue.
In the crankcase - I'm not sure... maybe?
Old 12-06-2009, 11:03 AM
nick1990's Avatar
well where ever it needs to be put...or can seafoam be put realy any where....dont plan on putting it in my oil though.
Where do most people put it in at?
Old 12-06-2009, 11:21 AM
cgeorge's Avatar
Seafoam states you can add it to your crankcase, carb, efi or gas tank. There are probably other locations they "approve" of.
I've used it in my gas tank with a motor that sat a while. I didn't notice a difference but that was kind of the point (stabilize fuel).
Old 12-06-2009, 11:58 AM
4Yoter's Avatar
I put about 3/4 of the can in through my vacuum lines then the rest in the gas tank
Old 12-06-2009, 12:20 PM
nlouvros's Avatar
well if it does work....think that in an old engine, youll have sludge blocking potential leak spots....if seafoam cleans that sludge away, there is more of a chance that your oil will leak out this nicely cleaned exit hole
Old 12-06-2009, 10:30 PM
rangerruck's Avatar
above dude is exactly right; this is going to clean the crap-literally- out of your oil crankcase, run it about 50 to 100 miles, then do a complete oil/filter change.
any of the crud, that is helping to close a leak, is gonna get taken out...
Eggslinger
06-08-2019 03:32 PM
thefishguy77
08-09-2015 04:15 PM
accuracy
08-04-2015 08:05 PM
icentropy
07-14-2015 10:23 AM
jjccamis
07-09-2015 04:00 PM
Quick Reply: Quick question about seafoam
