PLEASE HELP with my 95 4Runner issue - see my video here...
Old 06-07-2010, 05:31 PM
TidalVA's Avatar
Truck won't start and I'm getting this warning signal when I open the door/insert the key:
http://www.youtube.com/watch?v=O2Qwwsaqfns
Hey guys. I haven't had a chance yet to introduce my "new' 1995 4RunnerSR5 to the forum, but I have lots of info to post as this is a 240K truck that has had a pretty nice overhaul. Lot's of photos and info to come.
I pulled the carpet out of the truck tonight as I will be cleaning and reinstalling in the coming days. Removal went well, reinstalled the driver's seat and seatbelt and went for a spin to hear how loud it sounds without carpet. All that went well. Got home and decided to throw the husky liner in the driver's floorboard and shortly after getting the mat settled under the pedals, this warning signal began. I checked ALL the wiring under the drivers dash and things look okay, but the battery/wiring is disturbed. I really need to get it started to get to work tomorrow....
Has anyone experienced this "warning" with a 2nd gen before, and know how to correct it??
Thanks, Scott
Old 06-07-2010, 05:45 PM
JamesD's Avatar
That is an aftermarket alarm on the car. Tear that junk out and put it back to stock. It is very simple to do.
James
Staff
DeathCougar's Avatar
Pull that stupid aftermarket alarm out of there, and try it again.
Someone installed an aftermarket alarm with a circuit interrupt. If you take the lower dash panel off on the drivers side, you will likely find a rats nest of wiring. Cut all that useless crap out of there and fix any wires ruined by careless install "experts"
Old 06-07-2010, 06:21 PM
TidalVA's Avatar
Thanks guys. I find it hard to believe there was a security system on this thing at one time b/c I've seen no indication of one, but that will give me a starting point in the morning.
Old 06-08-2010, 04:29 AM
TidalVA's Avatar
Damn - you guys were right. There was a viper security system neatly hiding behind the lower dash. Once I removed a couple ground wires, I was able to start it no problem.
So I continued removing what was indeed a rats nest of wires until I pulled everything aftermarket out. In the end, the truck now won't start again, as I clipped what I believe was a ground wire for the ignition. Gonna have to tow it to someone today who can help.
One problem solved, another created.
Old 06-08-2010, 04:31 AM
TidalVA's Avatar
Old 06-08-2010, 04:51 AM
iamsuperbleeder's Avatar
lol, well that sucks
best of luck! AM security systems suck to get on a previously owned vehicle... if you're going to have one, it's best to get one and install it yourself
Old 06-08-2010, 07:49 AM
iselloil's Avatar
The viper installs most of the time as a plug in with a couple of grounds.Follow the harness from the ignition switch and see if there is a connection with three peices.Normally all connections are male female.Viper and some others use a in between connection and then goes to a control box of some sort.Once you pull this crap out it should start.
Old 06-12-2010, 09:14 AM
TidalVA's Avatar
For $30 my mechanic got me squared away. We are running again. Thanks for the security system heads up!
bigjstang
08-25-2021 12:41 AM
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
musashi86
California SoCal
07-07-2015 03:31 AM
Quick Reply: PLEASE HELP with my 95 4Runner issue - see my video here...
