Pan hard mod.
Old 07-11-2012, 09:19 PM
Jared7467's Avatar
Pan hard mod.
I was thinking instead of doing a panhard drop I could leave the mount higher and just have a tie rod with Hyme joints on it to center my rear axle on my 91 4 runner. Any thoughts of why this would not work?
Thanks you guys are the best,
Jared
Old 07-11-2012, 09:43 PM
TrikeKid's Avatar
Panhards work best when they are parallel with the axle, that's why you drop them, not just because of length.
Old 07-11-2012, 10:28 PM
abecedarian's Avatar
Yep. Heim joints won't compensate for the fact that under certain circumstances the axle will be pushed or pulled from the centerline of the frame with a panhard setup.
Old 07-15-2012, 05:39 AM
Fraser's Avatar
The best setup would include a drop bracket AND adjustable bar.
That way the angle would be kosher and you could adjust the length to perfectly center the axle.
Old 07-15-2012, 06:58 AM
Red Wagon's Avatar
When I get home from the mine I am installing my pan hard drop bracket from 4crawler.
Not having one in bent my sway bar links and at full droop my driveshaft is mere millimetres from the gas tank armour.
Might as well grab disconnects while your at it.
Old 07-15-2012, 08:12 AM
Actually, the best setup is Watt's Linkage.
Old 07-15-2012, 09:50 AM
Red Wagon's Avatar
That looks interesting. Is that custom made?
Old 07-16-2012, 08:49 PM
Well, it would be custom on a 'yota, but it's been around a while.
http://en.wikipedia.org/wiki/Watt%27s_linkage
Old 07-17-2012, 03:02 AM
Red Wagon's Avatar
I like the animation.
Thanks buddy. First time I've heard about one of these.
Old 07-17-2012, 05:42 PM
They've been around a while but are more expensive to implement than a panhard.
The animation was grabbed from wikipedia and shows how it works superimposed on some Ford thingamajobber.
he's gone
7
12-03-2019 07:08 AM
Gravel Maker
RuffStuff
09-08-2015 05:46 AM
BigMike
Marlin Crawler
09-03-2015 07:49 PM
falcon4runner
3.4 Swaps
08-06-2015 02:36 PM
irritech
07-27-2015 05:15 PM
Quick Reply: Pan hard mod.
