NOOB 89 4runner suspension?
Old Nov 8, 2007 | 10:16 AM
egon27's Avatar
hello
i'm new to the board and have question about suspensions for a 89 4runner. i'm looking to lift my 4runner at least 3" and just wanted to know what would be the best kind. i've read some of the post on this board about all the different types and brands..i've settled on the OME but not really sure where i can get them. also my 4runner has a lil sag in the back end. i will post pics when i get home. thanks
ian
Old Nov 8, 2007 | 10:32 AM
elripster's Avatar
Why are you set on at least 3".
I would start from the stand point of what tires you wish to run.
Frank
Old Nov 8, 2007 | 10:34 AM
Djlarroc's Avatar
I agree. We need some more info on your truck.
Old Nov 8, 2007 | 12:45 PM
egon27's Avatar
everything is stock minus the tires and exhaust..which are bfg a/t 31s and i'm looking to put bfg a/t 33s. don't want it any higher because it will be my daily driver
Old Nov 8, 2007 | 01:15 PM
eightnine's Avatar
Originally Posted by egon27
hello
ian
body or suspension?
Old Nov 8, 2007 | 01:17 PM
sh0kk86's Avatar
just get 1.5 bj spacers, crank the tbars a half inch, an add a leaf/hangers or even some newer leafs since yours are most likely sagging, and with the right backspacing on the wheel, you should be able to fit.
i fit my 33x10.5's on 8" rims with 4" bs'ing, and all i had to do was beat in the back of the front fenders(not noticeable at all), and when i flex, the rear tires tuck into the rear fenders just fine(this may be your only problem since your tires are wider, hwich is why a couple inches may be good to lift it.
Old Nov 8, 2007 | 01:21 PM
AxleIke's Avatar
I have zero lift, 33x9.50 AT's. No problem. You don't need 3". TC has a 33x10.50 on zero lift.
Get a body lift, it will work a lot better.
Old Nov 8, 2007 | 02:20 PM
egon27's Avatar
i want a suspension lift..where can i get OME suspension for a 1st gen 4runner, live in houston, tx ..o yea the tires i am thinking of getting are All-Terrain T/A, 33/12.50R15LT
Old Nov 8, 2007 | 03:27 PM
AxleIke's Avatar
TRDParts4U.
You will rub with that tire off road with just a suspension lift, unless you extend your lower bumpstops to limit your uptravel.
Old Nov 8, 2007 | 03:32 PM
elripster's Avatar
If you check our page www.sdori.com we have a list of vendors you can check out. One of them is in Texas which will make shipping cheap and bundles our spacers with other stuff to make a kit.
People fit 33X12.5"s with the spacers and a 2" body lift. As mentioned, the 33X10.5's fit stock. The suspension lift (spacers) will help with flex which is good. The body lift will help with clearance which is also good if you want the wider tires.
I would stay away from the bracket style lifts.
Frank
Old Nov 11, 2007 | 08:30 PM
egon27's Avatar
Thanks for the help guys
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Cdn-wilderness
Jul 10, 2015 07:43 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
