No start..but wait...now it starts?
Old 07-05-2009, 08:55 PM
91Toyota's Avatar
Okay, I've experienced this twice in the past 4 months on my 91
Anyway, I let my truck sit for maybe 8 hours or so...go out to my truck, turn the key and nothing. All the normal lights light up, I can turn my lights on, but it does nothing. After awhile of doing that I gave up and poked around under my hood and pondered a little. Then, tried it again and still didn't work. I did it a couple more times (turned the key from "on" to "start") and it cranked for about 6 seconds or so and I put my foot on the gas and it started. It ran fine after that. I've left my truck for 4 days at one point and it didn't do that.
Any thoughts?
Thanks a bunch!
Old 07-05-2009, 08:59 PM
swapped89's Avatar
does the starter click when u try crankin it over
Old 07-05-2009, 09:18 PM
91Toyota's Avatar
Nope. No noise at all. I was thinking the starter was finally going out so I hit it a little bit with a hammer and didn't make a difference.
Old 07-05-2009, 11:11 PM
awdjunkies's Avatar
Fuel relay/filter/pump would be my guess.
Old 07-05-2009, 11:50 PM
91Toyota's Avatar
I think I should replace my filter anyway, but how would that cause a no-crank condition?
Old 07-06-2009, 02:34 AM
abecedarian's Avatar
Next time it acts up, see if you can jump the starter with a wire and get it to spin and also check for voltage at the starter wire when you turn the key.
Old 07-06-2009, 03:27 AM
TNRabbit's Avatar
Either a bad ground or your relay or ignition switch is going out.
Old 07-06-2009, 09:17 AM
87topless's Avatar
I had the same problem on my '87 4Runner. Turned out a ground strap was loose going to the firewall and the main ground strap to the engine was loose. Once both were tightened, it has started ever since.
Old 07-06-2009, 10:32 AM
bugs1961's Avatar
I've seen a neutral safety switch (automatic) and an ignition switch cause these problems. On my Mother in Law's '89 I had a real hard time figuring out her intermittent no-crank problem because it never seemed to happen when I was around. Her ignition switch had excessive resistance in the switch when it was hot but it still showed continuity and voltage at the starter when the key was turned to start. But not enough current was flowing to activate the solenoid. Like Abecedarian suggested, I jumped the starter and it turned right over. To see if it was her ignition switch or the neutral safety switch, I ran a temporary wire from the IGN1 (pin 2) to the STA (pin 1) of the ignition switch connector through a momentary-on, push-button switch. With this setup she would use the switch if the key didn't work. Every time the key didn't work, the temporary switch would work so I knew it was the switch that was bad. A new ignition switch solved her problems.
Bugs
Old 07-06-2009, 10:58 AM
Ezrider_92356's Avatar
http://4crawler.com/4x4/CheapTricks/...shtml#EasyTest i am going threw the same thing with my Toyota right now just started acting up a couple days ago on an 1year old rebuilt starter, i just replaced an 6 month old reman alternator i have lifetime guarantee's on both but thinking about just repairing my starter as described in that link
Doug4320
03-24-2018 10:11 PM
ZONAYODA
07-13-2015 07:17 PM
Poncho0206
07-10-2015 06:21 PM
raiderhawks00
07-08-2015 06:23 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: No start..but wait...now it starts?
