no rear heat <4runner>
Old Dec 12, 2007 | 02:34 PM
jtlinna3vze's Avatar
checked all the fuses.. the relay.. all good.. any ideas?
Old Dec 12, 2007 | 02:43 PM
Tofer's Avatar
Sponsor
is the <4runner> part really needed? and do you really use it?! i found it not be helpful at all....
check to see if you have power to the switch....
Old Dec 12, 2007 | 03:18 PM
InternetRoadkill's Avatar
Motor burned out?
Seriously though, the rear heat is dead weight in a 4R.
Old Dec 12, 2007 | 03:20 PM
linuxrunner's Avatar
Originally Posted by InternetRoadkill
Motor burned out?
Just curious why? does it not work good? I do not have rear heat in mine and was thinking about putting it in.
Old Dec 12, 2007 | 03:24 PM
They rarely get used and just take space away from the center console. They also add a lot of extra connections and plumbing to the cooling system.
I removed mine. The plumbing and valves were corroded and expensive to replace. I don't think it was ever used.
Old Dec 12, 2007 | 03:37 PM
Tofer's Avatar
Sponsor
they are just not very efficient....
Old Dec 12, 2007 | 06:56 PM
95RunnerSR5's Avatar
and they only blow on the feet
Old Dec 13, 2007 | 03:53 AM
GSGALLANT's Avatar
The rear heat in my 2002 is awesome... I can sweat out the rear passengers if I keep it on high.
In my '93, the P.O. had the hoses disconnected, so I suspect that the core or lines were leaking. I wish it worked though. I may eventually take a closer look at it to see if I can fix it.
Old Dec 13, 2007 | 07:58 AM
funjumper's Avatar
I never sit in the back seat, so I pulled the rear seat heat as part of a 3.4 swap.
I have a '94 4runner. I pulled out the pipes in the engine compartment, and the pipes that run from the engine compartment to the rear seat heater. I looped a section of hose to seal off the rear heater core. As of this writing, I haven't pulled out the console parts. I'll have to take a look at the FSM to see how much of a hassle it it. The parts are all in great shape, my 4runner is a clean California truck.
In other words, if you are looking for the parts, we might be able to work out a deal. PM me if you are interested.
Old Dec 13, 2007 | 02:18 PM
i dont use it right now. its not working.. but id like to see if it helps.. it only hits your feet but thats what im going for..
Old Nov 2, 2011 | 01:28 PM
crazy4runner's Avatar
Same here too, my rear heater that goes to the feet is disconnected as well so I'm viroid how do you fix this issue?
the1998sr5
15
Jul 14, 2020 08:35 PM
jjrbus
Jul 19, 2015 02:06 PM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
hangtown88toy
Jul 10, 2015 02:33 PM
