Newbie Help
Newbie Help
I just bought a 87 4Runner. I have the diverside window switch working great now after a little rework. I am still having issues with the passenger side. It will not work at all. The window motor is good on the passenger side it goes up and down with drivers switch. I dont seem to have power to the passenger switch. I have looked at the fuse block for the window realy and can not find the relay there. I also took out the door lock controller and the windows still worked. What am I missing?
I ended up pulling the switch apart and bent the contacts a little bit. You might have to go back and forth untill you get it right. It will also play with the driver side so check it after you get done to make sure both sides work.
Big Little Bear
230
11-13-2023 11:42 AM
hiluxinargentina
09-30-2015 05:51 PM
