New Headlight Q's
Old 01-22-2008, 05:29 PM
path's Avatar
New Headlight Q's
Gonna step up the lights to some new ones. Going to get the H4 housings and some fatboy bulbs.
This is probably a stupid question, but the harness to get from 4crawler would be the dual H4 correct?
Should I step up to the HD o HO harness as well?
I have a switched ground too right?
94 Pickup 22re
Old 01-22-2008, 05:32 PM
Elton's Avatar
yes its a dual h4 and yes you have a switched ground
Old 01-23-2008, 04:28 PM
shaeff's Avatar
hopefully you'll get HELLA e-code housings, and not some cheap ebay junk...
Old 01-23-2008, 06:05 PM
path's Avatar
I was going to get IPF housings, those are pretty good right?
Old 01-23-2008, 06:45 PM
shaeff's Avatar
i just looked them up, and i'd still go with the hella e-codes, along with some good osram bulbs. (not sylvania silverstars. ugh)
Old 01-23-2008, 06:48 PM
4Crawler's Avatar
As noted above, you are getting the H4 headlights so you would want the H4 harness to match the bulbs. And Toyotas mostly use switched ground wiring as noted:
- http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
As far as the Heavy Duty and High Output options, that is up to you. The HD option will ensure proper high beam indicator operation even on vehicles with high loads on this part of the circuit:
- http://www.4crawler.com/4x4/CheapTri...tml#HDresistor
The High Output relays are a good idea if you are running 100 watt or higher bulbs:
- http://www.4crawler.com/4x4/CheapTri...shtml#HOrelays
Old 01-26-2008, 04:57 AM
Belize Off Road Team's Avatar
by the way, you more than likely dont need to change your headlight wires. i didn't and i'm running Hella 100/80W H4 bubs in my 91' V6 petrol
i'd pst pics but Photobucket is not working right now.
Old 01-26-2008, 09:35 AM
Morphine's Avatar
Don't assume here. Roger Brown provides a very simple test to see if you need to upgrade the harness or not.
http://www.4crawler.com/4x4/CheapTri...ml#VoltageTest
Try these steps first and then make your decision. I for instance was more than 1.1V off on my readings from the battery to the headlights. Thats a pretty big drop.
-=Morphine=-
Old 01-26-2008, 03:29 PM
shaeff's Avatar
yeah, just because they light up doesn't mean that they're lighting to their full potential.
you want the max voltage you can get right to the headlight. the light will disperse better, and be much, much brighter.
Old 01-27-2008, 12:46 PM
standardbyker88's Avatar
i have some of the ebay h4s. they are much better than the stockers. they came with some japan labled blue bulbs. i like the look of them both on the truck and the light they provide. im not saying their arent better housings or bulbs. and i will be installing my own harness with bigger wire and relays to let them achieve better voltage. but if the short answer you want is will you need to change the wiring for an h4, no. they use the same style plug. for the 29 bucks i spent shipped, im happy. and they have a 194 port down low too. i put in some purple leds their. yet to wire a switch to them though.
Old 01-27-2008, 02:06 PM
RobD's Avatar
I went with the Hella kit and noticed a dramatic difference right off the bat. Been experimenting a little with bulbs and I'm now running GE Nighthawks, which provide me a nice, white lighting. I'm contemplating the wiring harness upgrade, to get just that little bit extra.
Old 01-27-2008, 04:19 PM
shaeff's Avatar
4crawler's harness looks excellent.
i rewired mine using two bosch 30A relays. one for high beams, one for lows. it even made a difference with the HID's.
Old 01-28-2008, 04:01 AM
PCE91V64x4's Avatar
Yeah, by the way, Sylvania Silverstars are made by Osram Sylvania. When I lived in Germany, they were sold as Osram Silverstars. The Sylvania name brand seems to be for the Western Hemisphere, since everywhere else I have seen them as Osram.
Old 01-28-2008, 02:01 PM
shaeff's Avatar
^ do more research. osrams are much higher quality than the junk we get here.
kawazx636
10-06-2021 03:03 PM
4banginRunner
11-13-2015 05:23 AM
mreagen
10-05-2015 04:27 PM
beltcutter
09-30-2015 06:14 AM
JPV
09-28-2015 03:15 PM
Quick Reply: New Headlight Q's
