Need vacuum line help 86 22RE
Old Nov 24, 2010 | 03:07 PM
bicklebok's Avatar
Would someone be so kind as to look at this picture and tell me where this line is supposed to connect to? 86 22RE motor
Well, I couldnt upload it. Says its too large. maybe if one of you could PM me with your email address, I can email you the picture.
I have one more that I need to figure out as well.
Thanks guys!
[IMG]file:///C:/DOCUME%7E1/Aaron%27s/LOCALS%7E1/Temp/moz-screenshot-2.png[/IMG]
[IMG]file:///C:/DOCUME%7E1/Aaron%27s/LOCALS%7E1/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/DOCUME%7E1/Aaron%27s/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG]
Old Nov 24, 2010 | 04:06 PM
takeitoutgetitdirty's Avatar
If your 86 is like mine, you can search for vacuum diagrams on here or on google. Mine doesn't look anything like the 86re it is more like the 88re.
Old Nov 24, 2010 | 04:15 PM
bicklebok's Avatar
Thanks for the help, but I have tried that. There's even a diagram under the hood, but it doesnt have this line in it.
Here's a link to the pic....I hope!
http://www.flickr.com/photos/56313352@N06/5205112923/
Its the line my finger is on. Right now I just have it plugged off.
Old Nov 24, 2010 | 06:45 PM
Looks like the line that goes to the the vsv or one of the valves thats supposed to be on top of the valve cover.
If i can get my pics to load i have some that show where the lines run to and from.
Old Nov 24, 2010 | 07:13 PM
combatcarl's Avatar
on mine, (89) one goes down to plethora of hard lines along side of head, and the one your finger is on connects to the blue VSV, left center of valve cover.
Old Nov 25, 2010 | 04:12 AM
bicklebok's Avatar
I think I may be missing something. Look at this photo.
http://www.flickr.com/photos/56313352@N06/5206691602/
You can see in this photo there are 2 lines that arent hooked to anything that have a screw in them blocking them off.
Im not sure how important these lines are. Truck runs fine but it does sound like I can hear a vacuum leak somewhere, and I just want everything the way its supposed to be. You know how we are about our trucks?LOL
Thanks for the help! Happy Thanksgiving!
Old Nov 25, 2010 | 01:21 PM
bicklebok's Avatar
Not sure what the function of these parts are. Truck is running ok without them. Any guidance?
Old Nov 25, 2010 | 01:29 PM
PismoJoe's Avatar
Your missing the rear VSV. Its only present on 4WD 22RE's to aid in cold starts. Thats where that line is supposed to go, it sits on the back right side of the valve cover.
Old Nov 25, 2010 | 01:32 PM
PismoJoe's Avatar
Here's a diagram for the 4WD 22RE. Mine is an 86 as well, so I bookmarked this picture. It will help you for many moons
http://www.utoyot8.com/Picture.aspx?...ccode=&ppName=
Old Nov 25, 2010 | 02:54 PM
bicklebok's Avatar
Awesome! Thank you so much! Now I need to find out if it is an aftermarket part. I noticed today the front VSV has a broken nozzle on one of the vaccum line connections, so its not connected either. I tried to glue it back but couldnt. I will need that part too.
I cant thank you enough for the help!!
Old Nov 25, 2010 | 06:02 PM
4Crawler's Avatar
Or just bypass that missing VSV:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/10.html
My understanding is that VSV is more of a hot start aid, keeps the fuel pressure high in hot conditions to prevent a sort of vapor lock. I've had mine bypassed for 6+ years now and no hot (or cold) starting issues.
And that 3-port vacuum fitting at the back of the intake usually feed the FPR with one port, the factory cruise control (if installed) from the 2nd port and normally the 3rd port is capped. I used that for a vacuum gauge on the dash.
Old Nov 25, 2010 | 06:37 PM
4Crawler's Avatar
Originally Posted by razed
4crawler, I think your right.
Funny thing is that VSV is only present on 4WD/22REs. Why would the same fuel pressure issue not happen on other vehicles with 22REs.
Old Nov 25, 2010 | 07:13 PM
myyota's Avatar
It looks like the rear vacuum line should go to the fuel presure regulator.
Old Nov 26, 2010 | 03:20 AM
bicklebok's Avatar
4wd are higher so the air is thinner?
LMAO
Thanks for the pic and explanation 4crawler! i will bypass mine too.
Old Nov 26, 2010 | 05:41 AM
BLKNBLU's Avatar
A little late to the party as usual, but here are some pics from an old thread I posted.
The thread: https://www.yotatech.com/forums/f116...99/index5.html
The pics:
I learned something here too about the cruise control. I alsways wondered why mine only used one port but all the diagrams show two. Now I know. Cool.
smthwsn357
May 1, 2024 07:28 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
