need some input
need some input
i have an 89 4runner
v6 5sp
i got some free lift blocks from a buddy
also had all the parts to do a ubolt flip
now should i go to the stock locations or inboard the shocks?
and do i need to crank my torsion bars?
my rear body seem is at 20 inch's front is at 18 3/4
first pics is before the block
all others are after
v6 5sp
From what i can see of your rear springs, there shot and need to be replaced. I would never recommend that anybody use lift blocks, but that`s up to you, in my opinion they can cause to many problems. Your better off using ball joint spacers to lift the front, if you crank the torsion bars up that will make the suspension very stiff and give you a hard ride.
I'm aware of the spring wrap caused by the blocks.
and have driven a truck with the torsion bars cranked ....its honestly not the different from my truck ..... my rears are shot .....any springs from a newer truck fit the 4runners ? they also need bushings...... bad
What i would recommend is buying a new set of lift spring when you can afford them, you will get a better lift and more flex. But if you want used springs, anything from 84-89 (4x4) will work on your 4Runner.
ok i see that we've missed the main question in here
to in board or not too?
bars will get cranked to give me an inch lift and spacers will be bought for it when i get new springs
83yotastockR
11
11-10-2015 06:54 AM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
