Need help with compression check????
Old 06-09-2007, 02:13 PM
rollcage's Avatar
Im just about to put together my 22RE turbo, and thought about doing a compression check before I install it in the truck. HOW?? Has anyone done a compression check while the engine is on the stand? Ive never tried it. Thanks for your time.
Old 06-09-2007, 02:20 PM
curtiswyant's Avatar
I'd basically hot-wire the starter to a battery, don't use a switch or anything, so that when you connect the + cable, the starter turns over. You need to hold the throttle wide open while you're doing this, too, or block it open.
Old 06-10-2007, 05:42 PM
rollcage's Avatar
I thought about that but i have nothing to mount the starter to?????
Old 06-10-2007, 05:44 PM
tc
tc's Avatar
Couldn't you just turn it by hand with a wrench on the crankshaft bolt?
Old 06-10-2007, 05:54 PM
TNRabbit's Avatar
You have to do a compression check with the engine warmed to operating temperature & turn it over with a starter.
Old 06-10-2007, 06:50 PM
☺☺☺☺ it, just wait until it's in the truck then. With the time you'd waste setting it up to run on the stand, you could probably have installed the damn thing and had a beer or two!
Old 06-11-2007, 05:12 AM
rollcage's Avatar
Well I guess I will just have to put it in the truck, then do a check, no big deal. I know your supposed to do a comp. check with the engine warmed up, I was just wondering if their was a quick engine stand check that I could do. Thanks for the help.
Sleaker
08-26-2020 06:03 AM
Team420
12-30-2015 01:31 PM
the1998sr5
27
11-17-2015 09:30 AM
o2raybid
09-04-2015 12:45 PM
thefishguy77
07-30-2015 10:59 AM
Quick Reply: Need help with compression check????
