Multiple issues with 87 p/u: bogging out, low mpg, stained drive way...
Old 02-29-2012, 03:36 PM
jjjjjoey's Avatar
First I'll start with the pics:
In the morning I warm up my truck and whats spews out of the exhaust pipe is staining the drive way. Its seems to last only when the truck is warming up. In addition to that I cant help but notice a strong exhaust smell.
This leads me to my next problem. I feel like Im getting terrible MPG. I Started recording the mileage I drove between fill ups (about a 13.5 gallon tank) and I'm not even traveling 200 miles before I'm on empty again. I have 235 tires squeezed on(Btw for people who are searching, 235s are the biggest you can fit on a stock height 87 p/u 2wd), but I doubt they would give me that much less MPG.
And finally, last night the creme (name of my truck btw) started to bog and die out like it was out of gas. At the time i thought it was because I'm still pushing my car to see how many miles I get on a tank. But I filled it back up and will driving home I could get past 30mph before it start to bog out and die again.
I tried driving it again to today and it did the same, but this time its started to do it around 50mph.
Any suggestions or opinions? I love this truck, and its really bugging me that I have this damn problems.
Old 02-29-2012, 04:25 PM
rworegon's Avatar
When is the last time you did a tune-up? Looks like it may need one.
Old 03-01-2012, 12:25 AM
SR25JD's Avatar
MAP Sensor/I Chnged it out running like a Champ,the old one was pouring to much gas ,i seen your photos mine was doing the same i found a used one @ the junk yard 40.00 new ones where to expenensive.....
Old 03-01-2012, 01:08 PM
jjjjjoey's Avatar
I couldn't tell you. A few weeks ago I changed the spark plugs and air filter and that was all. Along with the oil, I've never done any other type of maintainence.
Old 03-15-2012, 06:19 PM
jjjjjoey's Avatar
Where is the map sensor located?
After letting the car set for a day I drove it again and it ran fine--but still giving me somewhere around 16mpg.
But when I was getting low on fuel, it started to act up again--bogging out. I would step of the gas and it was completely unresponsive- no rev of the engine. I filled the tank back up and it starts to bog out after 35+mph. Its like the fuel is getting cut off....
Old 03-16-2012, 11:30 AM
meswoleshane's Avatar
I'd do a compression check, usually black spots are worn rings/valve stem seals letting oil get by.
Old 03-19-2012, 03:42 PM
jjjjjoey's Avatar
I checked the spark plugs and the number 3 plug was black and covered in oil...
Does that confirm the worn rings/valve stem seals?
Old 03-19-2012, 04:25 PM
ttrmike's Avatar
Is your truck a carb or EFI?
Old 03-19-2012, 05:31 PM
The oil on the plug means its getting through somehow. My experience with 22r's makes me suspect the rings first.
Old 03-19-2012, 05:32 PM
jjjjjoey's Avatar
22R, Carb...
Old 03-20-2012, 04:42 PM
ttrmike's Avatar
Check the carbs AAP (auxiliary accelerator pump) diaphragm for the cold idle running problems.
bigjstang
08-25-2021 12:41 AM
coryc85
09-09-2015 06:24 AM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Multiple issues with 87 p/u: bogging out, low mpg, stained drive way...
