Melting Battery Cable
Old 03-28-2015, 01:48 PM
shadowbirdie's Avatar
Surplused Tools
Yep Millball, I "Surplussed" my T&B Orange/Black handle crimpers when I got out of the Navy 35 years ago . Nothing better for 8 and smaller wires and crimps.. Still have my Metcal PS1 also, $700 seemed extreme so I got one on Ebay..
We high end solderers and assemblers bailed out many an Electronic Tech
Crimp FIRST, solder SECOND, solder whets into the joint no problem..
Simultaneous 1 and 2 just about always results in a disturbed (defective) joint
Good Luck J
Always remember that Direct Short equals MAX current!!
12 VDC@650 Amp can be quite spectacular for a short period of time
Nuclear Repair Electrician USN/ High end IPC certified solderer
Old 03-28-2015, 02:05 PM
RAD4Runner's Avatar
Originally Posted by chuckross1957
Amazon.com: Camco 47474 Black 5/16" Stud 24" Long 2-Gauge Marine Battery Cable and Lug Assembly Tinned: Automotive I just received one of these 2AWG Marine cables and it looks really nice, it has solid lugs. I don't know if any one else has any experience with these cables, but it looks to be very high quality. My original starter cable is about 32" long so a 3' section is going to be about 5" longer than the original cable. I don't know how this stacks up cost wise compared to having a welding cable custom made. I have some 1/2" wire loom from Harbor Freight to use with this new cable. http://custombatterycables.com/info_...wire_types.htm ...Interesting comments on custom battery cables.
Looks good to me, but if you intend it for the positive side, make sure you wrap it with red tape or heat shrink.
... I doubt if these off-the-shelf cables are soldered after crimping. Soldering maximizes electrical contact interface, AND fills voids in the crimp to help minimize accumulation of battery acid in those voids which lead to corrosion. Therefore, I would take the extra step of coating the crimp with liquid rubber tape thoroughly then protecting that with another layer of heat-shrink. Not much trouble to do but then I can forget about the cable for the next 500,000 miles
Old 03-28-2015, 02:10 PM
Odin's Avatar
Amazon.com: Camco 47474 Black 5/16" Stud 24" Long 2-Gauge Marine Battery Cable and Lug Assembly Tinned: Automotive[/ame] I just received one of these 2AWG Marine cables and it looks really nice, it has solid lugs. I don't know if any one else has any experience with these cables, but it looks to be very high quality.
Not bad.
The ones I want to try are sold by GenuineDeals and they've been at it a long time. http://www.genuinedealz.com/custom-cables?conductors=87
Made with tinned marine cables and tinned copper lugs with adhesive lined shrink tubing. They have many options of cable length, cable gauge, and lug hole diameter.
You can purchase directly from their site or from their eBay store, not as many options on their eBay store though.
http://stores.ebay.com/genuinedealz?...p2047675.l2563
Old 03-28-2015, 03:23 PM
chuckross1957's Avatar
Amazon.com: Allstar ALL76152 Red Plastic Battery Disconnect Protective Boot: Automotive Amazon.com: Allstar ALL76152 Red Plastic Battery Disconnect Protective Boot: Automotive
I got a set of these red terminal covers, most likely I'll use one on each end.
Old 03-28-2015, 03:57 PM
  #25
Odin's Avatar
Terminal covers are a good idea if you're still running a "standard" wet battery.
Since I purchased an Optima I haven't had a lick of cable trouble with corrosion near the battery in over 15 years.
Old 03-28-2015, 04:02 PM
  #26
bswarm's Avatar
I used to like the Optima batteries, but it seems like quality has gotten worse, the last one barely lasted through warranty and went dead during a freezing night. The only other battery worth anything is Interstate.
Old 03-28-2015, 04:12 PM
  #27
Odin's Avatar
lol, agreed.
I knew I should have edited that reply before someone jumped on the Optima bashing I got mine before the quality dropped.
I only mentioned them for the "style" of battery. The Odyssey/DieHard Platinum is gaining ground though.
Old 03-28-2015, 04:15 PM
  #28
Odin's Avatar
Teach me
Old 03-29-2015, 08:20 AM
  #29
Soldering fun in the past
Imagine if you will, soldering several wires on a component the size of a poppy seed under a microscope Sounds like Rod Serling introducing a Twilight Zone episode back in the 60's
Can't do it anymore, too old and blind
Old 03-29-2015, 08:25 AM
  #30
Odin's Avatar
Haha, dang that's nuts!
Old 03-29-2015, 12:19 PM
  #31
Dftt
Don't feed the Trolls
Bourbonblues
12-15-2017 05:43 PM
Williamemslie
14
10-05-2015 09:28 AM
Armstrong486
09-19-2015 12:37 AM
matt1833
09-16-2015 07:11 AM
toyotafreak98
09-10-2015 02:57 PM
Quick Reply: Melting Battery Cable
