Loud "CLUNK" when turning at full lock...ideas?
Old 09-20-2006, 03:41 PM
Bassinfool's Avatar
Like the title says, sometimes when I'm turning my truck at full lock (either direction) I hear a very loud Pop or Clunk (Descriptive, no?) sound from the front end, sometimes once, sometimes two or three times. It started after hitting a pretty hard pothole while doing some fast trail running one day. Anyone have any ideas? I'm guessing I've got a broken tooth in on one of my front axles or the front diff, but I don't know if that would cause the sound or not. Thanks in advance!!
Old 09-20-2006, 03:53 PM
Yota82's Avatar
Lube the steering stops.
Old 09-20-2006, 07:04 PM
BuujinBejiita's Avatar
^^^^Details? Mine does the same(not so much after the lift) But my 88 truck did it also, My uncle that sold me the truck said it was a steering bolt stopper?
Old 09-21-2006, 10:10 AM
Yota82's Avatar
The truck in the picture doesn't have steering stops, the a arms are not stock but that is where they are located. On the lower a arm there is the part that it comes in contact with the circled part. Lube both parts on a regular basis and you will not hear it. There is supposed to be a plastic cap on them but those don't last long.
Old 09-21-2006, 10:12 AM
04 Rocko Taco's Avatar
THANKS!! been having that same problem!!
Old 09-21-2006, 12:30 PM
Bassinfool's Avatar
Outstanding! Thanks!
Old 09-21-2006, 03:25 PM
TNRabbit's Avatar
I wish I had a dollar for every time this question has been asked in this forum; I'll bet it happens at least once a week!
Old 09-21-2006, 05:28 PM
86SR522REEFI's Avatar
I thought it came from the factory that way lol
Old 09-21-2006, 08:27 PM
I did too, kind of like the factory 'toyota tick' lol.
Old 09-21-2006, 09:14 PM
Spanky's Avatar
whats the best stuff to lube that with??
Old 09-21-2006, 09:35 PM
Elton's Avatar
any type of grease and the reason the do that is they use to have little plastic caps and well they dont last long
Old 09-22-2006, 12:01 AM
AcidicDreams's Avatar
Anyone have an idea of another more permanent fix? There has to be something you could add to the end of the bolt that would last longer than plastic or grease...
Old 09-22-2006, 01:39 AM
rocket's Avatar
took me forever to find this thread due to the stupid title but here it is...
https://www.yotatech.com/forums/f2/2nd-gen-4runner-68244/
and if it's not the steering stops, it could be what others are saying in this thread...
"what's that clicking noise i hear when i turn?"
https://www.yotatech.com/forums/f116/whats-clicking-noise-i-hear-when-i-turn-80485/
Old 09-22-2006, 02:04 AM
TNRabbit's Avatar
The more permanent fix is to remove them entirely. I haven't figured any reason I need them...
Old 09-22-2006, 07:05 AM
Yota82's Avatar
https://www.yotatech.com/forums/showthread.php?t=80485
Clicking is usually associated with CVs, so most likely an axle.
Old 09-22-2006, 07:26 AM
That "rubberizer" spray paint? Its made for tool handles and stuff, you spray on several coats and it actually forms a foamy rubber handle...you could spray the end of these stops with that stuff....voila make a permanently bonded rubber cap... work? yes? no?
Old 09-22-2006, 07:43 AM
brandontrek's Avatar
i think the rubberized would wear quickly....something is needed like a metal roller or a hard polyurithane cap. i think they would do the trick
personally i love the look on people's faces when i make a sharp tunr in a parking lot.....its a mix of and:cry:
Old 10-02-2006, 02:23 PM
Bassinfool's Avatar
I greased them up & still, CLUNK! There's a groove worn smooth across the middle of both stops; what about taking them off & grinding a rounded top on them? I'm sure it would only be temporary, but would it help?
Old 10-02-2006, 04:39 PM
Sponsor
Tofer's Avatar
the way i fixed it was do a SAS... hasnt made that clunk since!
Old 10-30-2006, 03:15 PM
itsmeagain5789's Avatar
Ball joint. myne was doing the same thing. kept on embarassing the hell out of me when i was doing donuts cause it sounded like the axle was gonna fall off. but yea, it was the upper ball joint. and she's perfect now.
jasonty
41
12-23-2018 01:00 PM
jerusry
10-19-2015 05:28 PM
Nailit69
Diesel Swaps
07-21-2015 05:28 PM
MTLroadierunner
07-20-2015 03:07 PM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: Loud "CLUNK" when turning at full lock...ideas?
