left brake drum and backplate soaking in gear oil
I suggest you start here:
http://www.ncttora.com/fsm/1990-1995...e/rearaxle.pdf
Unbolt wheel, pull off drum, un-do the parking brake cable and unbolt (2 10mm bolts), unbolt brake line (10mm), unbolt 4 nuts on backside (14mm), pull out axle completely. Pop out old seal, tap in new one, put together in reverse order. It's realllllllly easy. Good luck.
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
