Just Armour linered my entire 94 pickup. 56K beware!!
#82
#84
sorry but one post up and there a email where you can get it
#85
jollygreen,
the instructions recommend that the truck be the same color as the tint that you used. do you think that i could get away with out doing this. i have the runner in primer and original paint which is red or maroon. i was planning on going white but the instructions says not to go with white because of yellowing, so i think i am going to do a lite gray. so my question is do you think that if i was to tint it a gray that it would cover the red on the truck?
you also said that the tint that you used was a base and a clear and that if you was to do it over you would do it different, could you tell me what you would do?
#86
how's it sound?
i am now thinking about spraying the entire truck inside and out.
i'm also thinking about putting that peel n' stick sound deadener inside the panels and on the floor, THEN LINING OVER IT. that should make the truck Lexus quiet!
what do you think?
TheBFA
02-15-2020 06:55 AM
87SR5justin
09-29-2015 02:50 PM
