I've got a few "what is this" pictures.
Old 02-23-2007, 08:57 AM
skife's Avatar
thanks to a friend of mine for being the finger.
whats this plug?
1.
What vaccume line goes into here?
2.
What does this adjust?
3.
What's this thing off the header?
4.
Old 02-23-2007, 09:01 AM
deserttoy84's Avatar
1 EDIT: thought u were pointing at somthing else
2 i dunno
3 looks like you idle adjustment
4 is for the smog system
Old 02-23-2007, 09:11 AM
Th3duke's Avatar
1) plug should go to a VSV ype valve ( I have 3 on mine, and you only show 2 on the cover)
2) should be going to either the EGR or the VSV that is missing
3) Air valve (don't remember what it's called) U should have to mess with it -- do you have air?
4) Coolant tube
is it running rough at all? I would at least block that missing tube part.
Old 02-23-2007, 09:16 AM
skife's Avatar
4) Coolant tube
there is 3 on mine, and they are all plugged in, there is just that random plug unplugged.
there is like a blue one, grey one and brown one plugged in.
it runs real real rough.
my truck did have A/c at one time.
Old 02-23-2007, 09:19 AM
4) Coolant tube
coolant flowing through the exhuast?? number three IS an idle adjustment.
Old 02-23-2007, 09:28 AM
PirateFins's Avatar
1. Not connected to anything on mine as well. But it is a connector for a VSV.
2. Not sure I'll look at mine.
3. Idle up adjustment for AC
4. allows exhaust gas to go to the EGR circuit.
Old 02-23-2007, 09:30 AM
fthertime666's Avatar
1. was your AC idle up vsv plug
2. Thats the pair valve, one of your vsvs should have a vacuum line going to
it, trace all the lines from your vsvs to the hard lines and see if one of those hard lines is missing a hose on its end.
3. that is your AC idle adjustment
4. emissions junk, for the pair valve
BTW if you have your original hood there should be a vacuum hose diagram
pasted on the underside of it.
Old 02-23-2007, 09:34 AM
Th3duke's Avatar
4) is Secondary Air injection manifold and should go back to a resonator
Sorry 'bout that but right beside (or in front of it) is a "return coolant tube" that looks exactly like it (hooks up to the timing cover coolant).
Old 02-23-2007, 09:40 AM
pair- pulsed air injection resonator
I know the coolant line you are talking bout, forgot to hook it up once
Old 02-23-2007, 10:06 AM
PirateFins's Avatar
his AC idle up VSV is connected, white connector, you can see the vacum lines running from the idle up adjuster screw to it.
Old 02-23-2007, 11:31 AM
SoCal4Running's Avatar
#2 is your fuel pressure regulator, which should have a vacum hose that goes to a vsv on the rear top of your valve cover
Old 02-23-2007, 01:50 PM
SO STUPID!!!!! Now I have to go find my cat-o-nine-tail and thumb screws!!!man! I so should have seen that!
Old 02-23-2007, 11:07 PM
trythis's Avatar
I was under the impression that #3 was the vacuum controlled idle booster for power steering and AC.
The idle adjustment is the straight slot screw just below the number three in the date on the photo #3
nvwiggins
13
06-16-2016 03:05 PM
Obmi
10-30-2015 04:27 PM
Mudlover
09-02-2015 03:50 AM
GeoRoss
07-24-2015 03:03 PM
Quick Reply: I've got a few "what is this" pictures.
