I've got a few "what is this" pictures.
thanks to a friend of mine for being the finger.
whats this plug? 1. http://img81.imageshack.us/img81/5949/dsc04685ac9.jpg What vaccume line goes into here? 2. http://img244.imageshack.us/img244/3205/dsc04686mh9.jpg What does this adjust? 3. http://img244.imageshack.us/img244/3813/dsc04687xr3.jpg What's this thing off the header? 4. http://img402.imageshack.us/img402/1039/dsc04688gj2.jpg |
1 EDIT: thought u were pointing at somthing else
2 i dunno 3 looks like you idle adjustment 4 is for the smog system |
1) plug should go to a VSV ype valve ( I have 3 on mine, and you only show 2 on the cover)
2) should be going to either the EGR or the VSV that is missing 3) Air valve (don't remember what it's called) U should have to mess with it -- do you have air? 4) Coolant tube is it running rough at all? I would at least block that missing tube part. |
Originally Posted by Th3duke
(Post 50444431)
2) should be going to either the EGR or the VSV that is missing 3) Air valve (don't remember what it's called) U should have to mess with it -- do you have air? 4) Coolant tube is it running rough at all? I would at least block that missing tube part. there is like a blue one, grey one and brown one plugged in. it runs real real rough. my truck did have A/c at one time. |
(Post 50444431)
4) Coolant tube
1. Not connected to anything on mine as well. But it is a connector for a VSV.
2. Not sure I'll look at mine. 3. Idle up adjustment for AC 4. allows exhaust gas to go to the EGR circuit. |
1. was your AC idle up vsv plug
2. Thats the pair valve, one of your vsvs should have a vacuum line going to it, trace all the lines from your vsvs to the hard lines and see if one of those hard lines is missing a hose on its end. 3. that is your AC idle adjustment 4. emissions junk, for the pair valve BTW if you have your original hood there should be a vacuum hose diagram pasted on the underside of it. |
4) is Secondary Air injection manifold and should go back to a resonator
Sorry 'bout that but right beside (or in front of it) is a "return coolant tube" that looks exactly like it (hooks up to the timing cover coolant). |
pair- pulsed air injection resonator
I know the coolant line you are talking bout, forgot to hook it up once;) |
his AC idle up VSV is connected, white connector, you can see the vacum lines running from the idle up adjuster screw to it.
#2 is your fuel pressure regulator, which should have a vacum hose that goes to a vsv on the rear top of your valve cover
SO STUPID!!!!!:bang: :bang: :bang: Now I have to go find my cat-o-nine-tail and thumb screws!!!:hillbill:man! I so should have seen that!
I was under the impression that #3 was the vacuum controlled idle booster for power steering and AC.
The idle adjustment is the straight slot screw just below the number three in the date on the photo #3 |
