Input on Input Shaft
Old 02-06-2010, 08:18 AM
Gray1991's Avatar
I have a 1991, 22re, 4X4, W56 transmission. My clutch was starting to slip. I've removed the transmission and instead of a dust covered bellhousing, it was all oil! I think that the input shaft seal is leaking. The front bearing retainer (cover) is covered in oil and the clutch fork boot is all swollen. From the research I've done this is typical of a leaking input shaft seal. Also, the input shaft has some play in it. More play up and down, side to side than in and out. How much play is normal? Should I just replace the seal and hope for the best, or does the transmission need to be rebuilt? I'm also replacing the clutch and resurfacing the flywheel. I have not removed the flywheel yet, so I guess the rear main seal could be leaking. I guess I don't want to replace the clutch and then have it get ruined again. Any suggestions would be really appreciated. Thanks.
Old 02-06-2010, 08:25 AM
4Crawler's Avatar
What does the oil smell like? Easy enough to tell if it is gear oil or engine oil.
Old 02-06-2010, 08:37 AM
Gray1991's Avatar
Yeah. It smells like gear oil. I guess I'm still wondering how much play is OK for the input shaft. I just don't want to put a new seal in and then have the clutch ruined again because the seal continues to leak. I guess I should include that the transmission makes a lot of noise in 3rd and 5th gear.
Old 02-06-2010, 01:08 PM
bugs1961's Avatar
Sounds like the input bearing is loose or worn. There shouldn't be any play in the shaft, and yes, play in the shaft will cause the new seal to fail soon.
Old 02-06-2010, 01:25 PM
Gray1991's Avatar
Thanks for the info bugs. That's what I was afraid of.
83yotastockR
11
11-10-2015 06:54 AM
zanzabar0
10-11-2015 02:56 AM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
beltcutter
09-30-2015 06:14 AM
Quick Reply: Input on Input Shaft
