I Need Electrical Help
Old Dec 16, 2007 | 09:46 AM
CaliRunner's Avatar
ive got a 94 4runner 3.0 and i was driving one day and all of a sudden i lost all my power and it dropped down to 1000 rpm or less and then it died..well i got it towed home and i want through a few things and then it started..well tmy 1st problem was that i wasnt getting fuel and i diddent fix that it just fixed itself..im thinking its the fuel pressure regulator but anyways it worked ok after that i had alot more bogging problems after that and then i went to tow a friend home and after that i drove home and i notices it wasnt idleing good..so now that the motor is cool it wont start at all..im thinking its the timing since its miss fireing but i havent got a chance to check it out...plz help me out to narrow down my my search for the problem..oh yea and thers no check engine light that comes on either..
Old Dec 16, 2007 | 09:48 AM
CaliRunner's Avatar
oh yea and i had replaced the rotor cap and distribuitor cap and im working on getting a distribuitor next..
Old Dec 16, 2007 | 08:25 PM
idanity's Avatar
ground wire?
does your ECU give you any info?
Old Dec 17, 2007 | 05:07 AM
Onebadmudder's Avatar
Does it have a module in distributor? If so take it out and most auto stores will check it. Just a suggestion before you get all crazy and change distributor.
Old Dec 17, 2007 | 06:01 AM
Etype R's Avatar
Had the very same issue this past spring... It would randomly cut out, then start back up. It left me stranded at a hobby shop one night, and after I fixed a broken wire in the cab it started back up. So I had it fixed right?
Now at this time I had a complete wiring kit for my FJ40 on the way, and according to the tracking info it would show up Tuesday. So Monday night I pulled the FJ40 in the garage and ripped out all of the wiring. Tuesday the wiring harness came in, and I cracked into it as soon as I got home from work. I decided to run up to Napa to get a few more connectors before I started. Hopped in the truck, turned the key and it wouldn't start... And when it would catch, it struggled to idle. I think I wasted a good hour trying to start it, and figure out the problem.
So with the truck down, I started the wiring on the FJ40. I managed to get it running again that night, but still needed to run all the wiring for the lights. I got a ride to and from work the next day. Wednesday I wired up all the lights, and drove that to work the rest of the week with no top or doors in the cold....
Now back onto the truck, my bed bolts were all rusted to the point that I couldn't pull the bed off the frame. So I had to drop the tank, which was pretty full at the time as well. So I siphoned out as much as I could before dropping it. Once I got the tank out, I realized it was not my fuel pump. The ground wire to the fuel pump bracket had broken off at the tab. Went to the dealership and they had the brackets in stock, since it is a common enough part to fail.... The bracket set me back $100.
Old Dec 17, 2007 | 07:06 AM
TNRabbit's Avatar
check for codes first.
Old Dec 17, 2007 | 06:21 PM
mheart624's Avatar
does it have a flapper style MAf, i'd condem that ! my experience when ya got weird problems thats the fault!
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Sep 28, 2015 11:21 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 24, 2015 01:12 PM
xzen73x
Sep 14, 2015 03:00 AM
