I just did compression on my 22re , What do you guys think
I just did a compression reading on my 22re with the intake off and the exhaust off, and was getting 195psi across all 4? Is this good? I know the standard is around 175? And I use 24volts to turn over the engine? I have heard someone people saying 200PSI is too much, but I would not know why, That would just tell me that it is a really strong engine? Thanks!
i did a quick google search and came up with this
155-170psi
Factory Specs= 142 Minimum, 14psi variation between cylinders.
so your service limit is 140psi. as long as all the cylinders are above 140 and with in 14psi of eachother, i wouldnt worry about it
155-170psi
skoti89
07-08-2015 12:05 AM
