How To Set up the Fuel Pressure Tester? 92 4Runner
Old Aug 20, 2009 | 06:33 PM
NuWaveJedi
Guest
Posts: n/a
Does anyone know how to fasten the fuel pressure tester to a 92 4 Runner 3VZ-E, as well as the best way to do a fuel pressure test? Any insight on tools, fastening, and or techniques would be cool!
Thank You Sirs,
NWJ
Old Aug 21, 2009 | 08:18 AM
sb5walker's Avatar
Probably any of the Actron fuel pressure testers would do the job - but you'll need the correct banjo fitting. I THINK it's the 8mm one, but I haven't done the job so hopefully someone who has will pipe up. Here's an affordable Actron from amazon:
http://www.amazon.com/Actron-CP7818-...dp/B0006V2BI2/
You'll need to get the banjo fitting from Actron - I've read that they are fairly good about shipping things out. The fittings are listed as accessories for a more expensive tester but they used to be listed on the page for the cheaper tester, and I'm 95 percent sure the fitting works with both:
http://www.actron.com/product_detail.php?pid=16173
It's the "Banjo Bolt M8*1.0" listed on the left - again, get confirmation from somebody before you buy it; if no one posts here, maybe someone at Actron would know. I think it looks like the attached photo.
The steps for the test are here:
http://personal.utulsa.edu/~nathan-b...87fuelpump.pdf
A couple diagrams that may be helpful:
http://personal.utulsa.edu/~nathan-b...89fuelpres.pdf
http://personal.utulsa.edu/~nathan-b...90injector.pdf
Please post back with feedback on doing the test. A write-up would be even better.
zd92655
Mar 6, 2022 12:58 PM
JF9243176
Oct 8, 2017 04:21 AM
MadMax48
Jul 3, 2015 08:26 AM
JF9243176
Jun 24, 2015 04:53 AM
jmc88runner
Jun 18, 2015 03:39 PM
