How many bolts?
Old 04-25-2008, 04:59 PM
DanStew's Avatar
How many bolts?
I am pulling the engine and want to know how many bolts there are holding the 5 speed tranny bellhousing to a 22re? I want to make sure i got them all and the manual doesnt really show "how" many there are.
Thanks
Old 04-25-2008, 05:08 PM
bigt's Avatar
i would also like to know as im pulling my tranny tommorow as i just got my new tranny jack together \m/
Old 04-25-2008, 07:23 PM
fillsrunner4's Avatar
I believe its 9 bolts.
Old 04-27-2008, 02:44 PM
mudtoy1986's Avatar
ill go look at the engine i just pulled its still hanging from the chain fall
Old 04-27-2008, 02:47 PM
Staff
DeathCougar's Avatar
-4 bolts holding bellhousing to block
-4 bolts holding support brackets to bell housing
-2 bolts holding starter on
So 10 Total.
Old 04-27-2008, 02:51 PM
mudtoy1986's Avatar
ok there are 4 17mm2 at the top bellow the valve cover and one on each side at the bottom of the block there are 4 14mm bolts they are bolted to the supports that are on the lwer side of the block also the 2 15/14mm bolts that hold the starter on btw one of the 17 mm bolts at the base of the block are behind the clutch slave cylinder
hope this helps
Old 04-27-2008, 02:52 PM
mudtoy1986's Avatar
oopps someone got it before me
Old 04-27-2008, 02:57 PM
Staff
And I got it by memory
Old 04-27-2008, 04:42 PM
DanStew's Avatar
Well i got them off. So who has accidentally NOT put the top botls back in? Would it make a differnence if they were not used?
Old 04-27-2008, 04:54 PM
Staff
I wouldn't suggest that. Quick way to break things.
Old 04-29-2008, 04:50 PM
mudtoy1986's Avatar
yeah i would say that toyota put those bolts in the top for a reason lol
Old 04-29-2008, 05:09 PM
Luvmeye22re's Avatar
Ditto, there is a lot of torque flying around in that little bellhousing.
Old 04-30-2008, 05:13 AM
dirtoyboy's Avatar
Don't feel bad! I did the same thing last time I dropped a tranny. Stabbed it..then went to bed...came out the next day and forgot about the top 2 bolts
Luckily it only takes a few minutes to drop the crossmember and tilt back the bellhousing
some drunk guy
08-03-2021 06:09 PM
Zach_trun
01-22-2020 04:42 PM
mistershmi
01-05-2016 11:07 AM
JUICE222
10-13-2015 08:50 AM
JookUpVandetti
09-24-2015 08:56 AM
Quick Reply: How many bolts?
