Help me spend $500 on my 87 4Runner
I had to look again at your specs. If you're doing any offroading, you'll want skids and sliders. Just looking at the pics for the John Bull Trail, you'll definitely want sliders, and a front skid, if you don't already have one. If you go for a crossmember, keep in mind whether you might do dual cases down the road. I ran a single 4.7 case with the stock crossmember for almost 2 years, until I went dual cases. Of course, I've had a 4" suspension lift the entire time, so I had more ground clearance than you.
Trail Gear has a sell going for there Bomb ProofT-Case Mount on sale for $55. its heavy duty replacement. Fits Stock and modified dual cases. Im think of getting one. Just gotta convince the wife
http://www.trail-gear.com/transfer-case-mounts
#27
Have you considered running dual t-cases? Instead of the 4.7:1 gear set in one t-case you could pick up an adapter (probably 100$ used) and a second t-case (less than 50$ from a junk yard) and run dual t-cases.
#28
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
