help with gauges
Old 08-12-2006, 06:07 AM
ads86runner's Avatar
help with gauges
Another newbie needs some help!! Both my tach and oil pressure gauges are not working. Any ideas beside a fuse. The tach wasnt working when i got the truck and the oil gauge stopped working a couple of days ago. Also does anyone know if there are any replacement consoles out there and leather shifter covers. Mine are looking a little rough. Thanks!!
Old 08-12-2006, 07:04 AM
trythis's Avatar
your oil sending unit is probably bad. Your tach could just have a loose wire. Did it come with that set up from the factory or did someone add it in? You have an sr5? Make a signatur so we know what you have, engine, tranny, truck? etc.
Old 08-13-2006, 07:04 PM
Saint_Berzerker's Avatar
I had a problem with my oil pressure sensor having a loose connecter on it. It's a can looking thing that screws into the bottom of the engine. I finally just soldered the dang thing on there.
That's definately one gauge you want to work.
Dunno about the tach.
Old 08-15-2006, 03:08 PM
New sending unit in problem solved!!! Thanks :bigclap: :bigclap:
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
zanzabar0
10-11-2015 02:56 AM
Jdgarrison
10-01-2015 05:22 PM
dbollier123
09-29-2015 05:23 PM
Quick Reply: help with gauges
