help fuel problem
Old 08-17-2010, 10:54 PM
ej1bullet's Avatar
help fuel problem
hi my 4 runner wont start it rotates but it docent start i chek my fule preser and its at zero so i chang my fuel filter and also my pump and it still don't start i also jumpt the fuel pump and the fuel pump turns on but the car wont . i already put on a new Maine relay also cir cult opening relay ,efi realy and it still don't work ! any advice guys??
Old 08-17-2010, 11:05 PM
myyota's Avatar
How about telling us what year your 4Runner is and what engine it has ???.
Old 08-17-2010, 11:40 PM
ej1bullet's Avatar
its 94 Toyota 4 runner v6 stock
Old 08-18-2010, 10:09 AM
ej1bullet's Avatar
bummp
Old 08-18-2010, 10:20 AM
jaredbishop's Avatar
Try to pull a code. If that doesn't work you may have blown the EFI fuse. I had my o2 sensor wire burn and ground itself, blowing the fuse. New fuse was $2 at dealership. Repair wires before replacing fuse
Old 08-18-2010, 10:49 AM
ej1bullet's Avatar
i already check that i just have a egr code and i already replace the efi fuse and relay !!
Old 08-19-2010, 02:49 AM
ej1bullet's Avatar
thanks man for the reply i check the the efi relay but it came out good than i check the ecu fuse next to the driver side kike panale and it was blown so i check it with a test light and it dint have current on both sides!! im getting so frustrated that im thinking of sealing it but i love my truck so much i have so many memory's with it ...... i dont rally whant to do it
Old 08-19-2010, 02:51 AM
ej1bullet's Avatar
im thinking its the ecu what do you guys think??
Old 08-19-2010, 03:02 AM
ej1bullet's Avatar
i tride bulling a code today but it was rapid lee blinking y whold it do that the code look like this !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! unstated of code= !!_!=21 what and haw whold this happen??
Old 08-19-2010, 08:09 AM
Mike Shull's Avatar
You don't think you have fuel pressure? But you jumpered your fuel pump and it still won't start?
Have you tried spraying a mist of fuel in the intake to see if she will fire?
Spark?
Compression?
What do the spark plugs look like?
Old 08-19-2010, 08:10 AM
Mike Shull's Avatar
What happened the last time she ran? Did you park it and it simply wouldn't start back up or did it die out?
Old 08-19-2010, 09:59 AM
scope103's Avatar
I assumed you checked the fuel pressure with a fuel pressure gauge (usually hooked on near the pulsation damper, but zero is zero anywhere on the rail). I also assumed that you checked the fuel pressure with the pump running when you jumpered the FP connector. If the pump is running and you have no fuel pressure then it doesn't have anything to do with any relay or ecu.
Your fuel pump may be toast, or you may have a blocked fuel line (less likely, as long as it was running recently). Since you're going to need to drop the fuel tank to get to the pump, you can (gently!) put some compressed air on the fuel line to make sure it is clear up to the fuel rail.
Diagnosis: one step at a time.
Old 08-19-2010, 10:14 AM
ej1bullet's Avatar
Originally Posted by mike shull
you don't think you have fuel pressure? But you jumpered your fuel pump and it still won't start?
Spark?
Compression?
i think the bump i got a kragan is acting up on me
the compression not yet
there is spark and every thing from the ignition is new
thanks for the advice
Old 08-19-2010, 10:17 AM
ej1bullet's Avatar
Spark?
Compression?
every thing is new but im going to try fuel in the trhotal body thanks guys!
Old 08-19-2010, 10:19 AM
ej1bullet's Avatar
Originally Posted by scope103
i assumed you checked the fuel pressure with a fuel pressure gauge (usually hooked on near the pulsation damper, but zero is zero anywhere on the rail). I also assumed that you checked the fuel pressure with the pump running when you jumpered the fp connector. If the pump is running and you have no fuel pressure then it doesn't have anything to do with any relay or ecu.
Diagnosis: One step at a time.
my pump works when i jump it tats y i think it also has to with my relays or short also my 20 fuse for the ecu blew i chekt it with a test light and there is no cuernt
Old 08-19-2010, 09:06 PM
ej1bullet's Avatar
i finally made the fuel work it was a short on the air mass senser but it wont start i got fuel pressure and also spark i cheek my spark plug weirs and they are good any suggestions??
Old 08-19-2010, 10:56 PM
jpsstewart3's Avatar
Im sure you checked but doesnt hurt to mention looking at all the grounds to everything and checking for kinks/bends/leaks.
Im currently having an extremely similar problems (thread labeled "injection/starting problems" ) so Im definately paying attention here
Old 08-20-2010, 11:47 AM
ej1bullet's Avatar
thanks man ill keep a look out for grounds!
jbv808
08-06-2021 04:47 PM
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
gary4runner
09-24-2015 12:53 AM
shisha1999
07-13-2015 11:09 PM
Quick Reply: help fuel problem
