help!!! 95 sr5 pickup
Old 05-12-2009, 07:19 AM
wbthornton88's Avatar
So last night I puilled into a gass station to get a drink, got back in the truck and went to crank it and nothing happened. I have no idea whats wrong the battery is good but the truck is getting no power at all. Any ideas?
Old 05-12-2009, 07:40 AM
bjslade0269's Avatar
No dash lights or radio, anything? Or just no cranking?
Old 05-12-2009, 07:44 AM
no lights or or anything.
Old 05-12-2009, 07:52 AM
I would check the cable and battery terminal if you haven't already.
In the engine compartment there should be a 30 amp main fuse from the battery, I would check that also.
Old 05-12-2009, 07:53 AM
I also think there is a main relay in there.
Old 05-12-2009, 08:09 AM
I've had some problems with the connection to my starter before, would a bad connection there cause no power to the truck? Also is that fuse in the box right behind the battery?
Old 05-13-2009, 05:12 PM
ok well, I've checked the fuses and the positive and negative wires to the battery. This all seems to be fine. is there anything else? What about the little square box thats back by the cd player wires that says 12v light relay? would that have anything to do with it if it were to be bad?
Old 05-14-2009, 06:18 AM
desertcox05's Avatar
look real close at you battery cables. i've found corrosion inside the insulation preventing volts from getting through. and ck your gnd connections too, make sure they're clean and tight
Old 05-14-2009, 07:31 AM
wii_tarded's Avatar
Did you check the ground from the battery to the frame? Real easy to miss.
Old 05-14-2009, 08:29 AM
Gokumono's Avatar
I have had the same kind of problem....
What was/still is wrong with mine, is the negative terminal. I have it all the way tightened down, but is still loose, and on the rare occasion loses connection. I got a new terminal, but haven't put it on yet.
Point being. Make sure the terminal connections are tight and can't wiggle.
gary4runner
09-24-2015 12:53 AM
09-04-2015 09:27 AM
Jonny246
07-12-2015 04:51 AM
Cplmike
07-08-2015 08:47 PM
raiderhawks00
07-08-2015 06:23 PM
Quick Reply: help!!! 95 sr5 pickup
