Goofed on a Head Gasket replacement
Old Jun 27, 2009 | 08:39 PM
climber87's Avatar
So I'm finishing up a full rebuild of my 22re out of my 87 4runner. But I goofed when putting the head on tonight. I forgot the spacer/dowels that go under the one side of the rocker assembly and torqued the whole thing down. Then when I realized, I had to undo it all and then retorque it. I never lifted the head up off and am wondering if I need to go get a new gasket now or will I be alright. Also, will the head bolts be ok. It was seriously only torqued down for like 5 minutes.
Only reason that I'm not immediately playing it safe and ordering at least a new gasket from engnbldr is I need this project finished real soon...kinda running out of time. I guess I could just fork up the money and go get one from toyota...but not if its not necessary.
Old Jun 28, 2009 | 12:45 AM
Ezrider_92356's Avatar
as long as you did not move the head or break the seal you should be just fine
Old Jun 28, 2009 | 06:45 AM
screech's Avatar
head bolts will be fine. the length should be 6.417 from bottom to under the head. 6.417 is 6 3/8" The head bolts are not a torque to yield type of construction so no stretching of the bolts occurs during torque. Me personally wouldnt reuse the head gasket. Felpro from advance auto is the oem and 25 bucks.
Old Jun 28, 2009 | 08:55 AM
DupermanDave's Avatar
I'd say you should be fine. the head didnt move, didn't heat up from the engine moving, so there should be no impressions or warpage.
Old Jun 29, 2009 | 09:11 AM
climber87's Avatar
while i may be fine...i guess it is wise advice to go ahead an replace it...if the felpro gasket from napa or advanced auto will work. I'd rather try my luck with the one on it than pay the 60$ for one from toyota.
How well do the felpro ones work?
Old Jun 29, 2009 | 10:01 AM
I got a felpro one when I did the headgasket. they seem to do good, and I havent had any issues yet, though the headgasket was only done about 6 months ago and about 4000 miles ago
Old Jun 29, 2009 | 10:09 AM
jackwolf's Avatar
FEL-PRO is some sort of standard among the guys, that I talked to, who wrench for a living.
They come highly recommended; so I use them. They are a solid product. They do not disappoint.
Old Jun 29, 2009 | 10:58 AM
i have used fel-pro lots of times, very good gaskets
Old Jun 29, 2009 | 08:07 PM
climber87's Avatar
So I was at Advanced auto and thought I'd at least check out the "new design" Felpro. Probably would work ...but definitely less quality than Rock Gaskets...wish I wasn't such a perfectionist and just left well enough alone. I'll be grabbing a Toyota one tomorrow...hopefully one of the dealers has it in stock.
Old Jun 30, 2009 | 03:37 PM
Flash319's Avatar
I would disagree. Unless the OEM is a Fel-pro then I would not use them. Teds are much better.
Old Jun 30, 2009 | 05:29 PM
4Krawler's Avatar
I vote re-use both as long as motor hasnt been fired. Now......
Hi-Jack
I just got a "Rock Gasket" from Engnbldr in the master rebuild kit. Anyone used this gasket? I was considering forking over the extra $48 for a factory one just to be safe.... Then again money is hella tight.....
What do you guys think?
Old Jul 3, 2009 | 08:24 PM
4Krawler's Avatar
bump BUMP
Old Jul 3, 2009 | 08:29 PM
olharleyman's Avatar
My machinist looked at them I too got the ROCK GASKET FULL MASTER REBUILD KIT from engnbldr and he said it is top quality as far as aftermarket gaskets go.
Old Jul 3, 2009 | 09:30 PM
Dirt Driver's Avatar
Rock gaskets are adequate, not "top of the line." However, they do work, at least for the 22R-E. Mine has had a Rock head gasket for ~30,000 now.
Felpro gaskets are generally good. The 3VZE crowd would say otherwise, but 3VZEs need a miracle to hold the head gaskets anyway.
Old Jul 4, 2009 | 07:55 AM
4Krawler's Avatar
Hey thanks Harley Man & Dirt Driver, thats what i was looking for.
Old Jul 4, 2009 | 08:09 AM
4Krawler's Avatar
I think i'm gonna go with it. I mean i am using literally EVERYTHING else he sells basically.020 over pistons & rings, t-cover, oil & H20 pumps, gaksets, O/S Valves, 268 Torkr Cam, ect, ect...
the $48 is half of my injector rebuild I need from http://www.witchhunter.com which i'm going to consider manditory with my complete rebuild.
Old Jul 4, 2009 | 08:10 AM
idayota's Avatar
op...have you got to fire the motor yet? any issues?
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
Whatever123
Sep 30, 2015 12:12 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jnkml
Jul 6, 2015 01:20 PM
