getting heads machined, what else need to be done?
Old Sep 6, 2008 | 08:15 PM
Marcot1's Avatar
I finally got the heads of my 3.0 this evening while in the process of replacing the head gaskets. I'm planning on getting the cylinder heads machined by a local shop, what else should I have them do or should be expected during a head build.
There is nothing intrinsically wrong with the heads from what I can tell; I'll try and post some pictures later.
Thanks for any assistance.
Old Sep 6, 2008 | 08:45 PM
drew303's Avatar
pressure check, plain the mating surface
Since your this far in, I'd have em throw new stems seals in. You could install aftermarket cams if you wanted..
should get new head bolts, I'm not sure how critical that really is (I've never actually heard of someone having issues with reusing old bolts) I replaced mine when i put my new head on a few weeks ago, they were cheap from engnbldr
Also, it's a good idea after its all back together to run it awahile and go back in and re-torque the headbolts when they're hot. This assures they properly torqued. Same with the valves =)
goodluck
Old Sep 6, 2008 | 09:23 PM
abecedarian's Avatar
if the bolts are torque-to-yield you should NEVER EVER re-torque them and NEVER RE-USE THEM.
you can tell the difference when the instructions state to torque to some value, then turn the bolt a certan distance (say 90 degrees), then turn them again a certain distance.
If you DON'T have a final torque value to adjust to, the bolts are torque-to-yield and should never be reused or retorqued.
the very definition of 'torque-to-yield' means you tighten them until they are almost ready to break.
bigjstang
Jun 2, 2025 03:56 PM
cars-guy
Aug 16, 2020 06:59 AM
skoti89
Apr 30, 2016 10:44 AM
dumpster84
Apr 30, 2016 06:03 AM
Sep 4, 2015 09:27 AM
