Filling Tranny + T-case: From the top?
Old 11-07-2006, 10:59 AM
Bill's Avatar
Well, my new tranny is going in today(W56), but I'm curious: Can I fill the tranny and t-case from the top through the shifter holes? I figure I've got them off, and the interior pulled up anyways.
I guess the real reason I'm asking is because it's a bit of a pain in the butt to almost need to siphon fluid into it from the side.
Old 11-07-2006, 11:13 AM
all_terrain17's Avatar
Yes you can, most that fill this way do it to overfill and allow the transmission run smoother...Didn't work for me though.
Old 11-07-2006, 12:50 PM
rezrunner92's Avatar
You can do it from the top with the fill plug out and catch pan under. Then no worries.
Old 11-07-2006, 04:19 PM
943kgt's Avatar
i was able to fill my tcase from teh bottom with a squeeze bottle and teh tranny from teh top with about 4 ft of 3/8" fuel line. took some time to squeeze teh fluid through the line but it worked
Old 11-07-2006, 08:36 PM
toy283's Avatar
I prefer to fill from the top, it goes so much faster and you don't spend any significant time cramped under the truck. I just pull the check/fill plug and fill until it starts to run out. Once it's done dribbling out of the hole, I know it's full to where it's supposed to be.
Old 11-08-2006, 07:06 AM
rdlsz24's Avatar
I got what is basically a big syringe from AutoZone for under $10 to do all my drivetain fluids, and I have used for other things since. You stick the tube down in the bottle, suck the fluid into the syringe, put the tube in the filler hole for the tranny, diff, etc, and then push the fluid out of the syringe. Works slick.
Rob
Old 11-08-2006, 11:29 AM
Sonofmayhem's Avatar
x2^^^^
Old 11-08-2006, 11:50 AM
91_4x4runner's Avatar
Rob
Got any pics of that?
Old 11-08-2006, 12:53 PM
rdlsz24's Avatar
Mine looks just like this but it's black:
I just changed my tranny fluid on my car and each time I would suck up the fluid it would hold about a half quart, so it makes quick work of jobs like that.
Rob
Old 11-08-2006, 02:24 PM
MMA_Alex's Avatar
yep those suction pumps are worth every penny. Last time I changed trans fluid i used one of those cheap emergency gas siphon pumps, took me about 2 hours to change the 3 quarts including cleanup which was not fun. With the suction pump you should be able to put the fluid in in less than 20 minutes with no issues.
It can help to find a more flexible hose for it though to get into those tight spaces.
jasonty
41
12-23-2018 01:00 PM
yourrealdad
07-29-2015 11:08 AM
yourrealdad
07-21-2015 11:13 AM
Iceman4193
07-15-2015 04:48 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Filling Tranny + T-case: From the top?
