Engine Starts, but stalls after two seconds.
Old 03-05-2014, 11:15 PM
Yaop117's Avatar
Let me explain my situation. I recently adjusted the valves on my 1994 toyota 4runner with a 22R-E engine. I got it as my first car a little over a year ago and the valve spacing was horrendous so i finally decided to do something about it.
After I adjusted my valves to the specifications recommended by my hanes manual (.3mm exhaust and .2mm intake) I put the engine block and vacuum hoses back on and tried starting it. It started instantaneously, and when it runs it sounds fine. But the engine won't stay running for more than 2 seconds. even if i step on the throttle. The hanes manual suggests my problem is the vacuum hoses that are the issue but i'm pretty sure i have mine plugged into the correct spots. The other thing i was thinking it could be is the fuel pump so i plan on checking that when i get the chance.
Anyways, I was just wondering if anyone else has had this problem and could give me advice in case i'm looking for the wrong solution. Also if anyone has a Vacuum hose wiring diagram that they are willing to share, that would be nice as well.
This 4runner is my daily driver so i want to get it up and running ASAP.
Old 03-05-2014, 11:30 PM
Staff
Terrys87's Avatar
Is your air box wiring hooked up? Check for vacuum leaks as well.
Old 03-06-2014, 01:58 AM
Romans117's Avatar
Something didn't get connected back right. Go back over it.
Old 03-06-2014, 04:56 AM
92yoterDD's Avatar
Sounda like a MAF issue to me. Verify that it is plugged in tight and the terminals are in good shape. If all that checks out then you can hold the air door open on the MAF sensor and try starting it.
Marc's Avatar
Like TerryS says, it sounds like the Air Flow Sensor on your air filter housing isn't connected.
The fuel pump runs while the iginition key is in the Start position but relies on air flow to keep it on while in the Run position.
Old 03-06-2014, 08:41 AM
Yaop117's Avatar
Oops, I totally forgot to plug the cable back into my air intake box...
It starts up just fine now. Thank you guys.
Old 03-06-2014, 09:06 AM
Staff
Terrys87's Avatar
Glad to see you got it running. Always good when someone lets others know what fixed itas someone else may find your thread and help them.
JF9243176
10-08-2017 04:21 AM
94 Newbie
07-06-2015 04:23 AM
sonic concepts
07-01-2015 02:33 PM
Alex Bessinger
06-28-2015 10:05 AM
JF9243176
06-24-2015 04:53 AM
Quick Reply: Engine Starts, but stalls after two seconds.
