emergency steering question
Old 04-29-2012, 04:01 PM
Dreidel's Avatar
ok so i was driving my truck and sheered all the teeth off of my pinion
now i have all the stuff for a sas and perfect excuse to do it... now for the question what do i need to do in order to make my stock ifs box to work with the solid axle any help would be appreciated
p.s. its only a emergancy because i need to get my truck up and running decently quick
Old 04-29-2012, 04:09 PM
85TurboRunner's Avatar
I'm guessing your truck is currently 2wd since you gave absolutely no info and thats whats in your avatar.
If you are trying to use a 2wd steering box. Don't. Go get a 4wd box.
Old 04-29-2012, 05:22 PM
Dreidel's Avatar
haha knew i was forgetting something i have a 2wd 95 toy with 83 solid front and rear axles with probably everything to put together
will the 83 4wd box work fine
Old 04-29-2012, 05:28 PM
waskillywabbit's Avatar
No you need a 86-95 IFS 4WD steering box
:wabbit2:
Old 04-30-2012, 04:04 AM
Dreidel's Avatar
:wabbit2:
ok 1 why will the original steering box for the solid axle not work?
2 what do i need to do/make for the ifs box to work with solid front axle
Old 04-30-2012, 04:12 AM
Not trying to be ugly, but you need to do some more research and reading.
I would start with searching about installing SAS kits and particularly high steer. Numerous threads with pictures. Dropzone has a good thread on useful stuff bookmarked.
SFA box pushes front to back.
IFS box pushes side to side.
Not even remotely the same creatures.
You need an IFS style box to run high steer.
Frame mounting kit.
High steer.
Power steering obviously.
:wabbit2:
Old 04-30-2012, 07:27 AM
Dreidel's Avatar
Frame mounting kit.
High steer.
:wabbit2:
i didnt mean running high steer with sfa
do you know why the 2wd box wont work?
Old 04-30-2012, 07:30 AM
So what is #1 asking?
:wabbit2:
Old 04-30-2012, 07:38 AM
Dreidel's Avatar
:wabbit2:
1 was asking if the sfa box would go to my frame and work right (no high steer)
2 was asking if my 2wd ifs box will work with high steer
Old 04-30-2012, 07:46 AM
No.
:wabbit2:
glowz825
01-25-2022 09:28 AM
okamikai
04-30-2018 10:19 PM
delmert
09-30-2015 04:34 PM
gillesdetrail
08-03-2015 04:43 PM
bobpat
08-01-2015 09:25 PM
Quick Reply: emergency steering question
