The EFI fuse
Old Nov 16, 2007 | 12:21 PM
mudflap91's Avatar
The EFI fuse
I have a 91 4runner 3vze 5 speed ,The EFI fuse keeps blowing .I replace the fuel filter(was cloged) and its still blowing fuses. It runs at Idle(1 hr) but blows after running down the road for a few miles. I put a 15 amp fuse in and that last 2 mins but I put a 20amp in and that last a little longer. Also replaced the 30amp bus fuse. )-: Any ideas what to do next?
Old Nov 16, 2007 | 12:31 PM
4Crawler's Avatar
Common for a shorted out O2 sensor wire to cause the EFI fuse to blow. Check all the O2 sensor wiring, especially near the hot exhaust. Common that it touches the exhaust and shorts to the exhaust itself or the insulation melts and the sensor and shield wires short out.
Old Nov 18, 2007 | 07:42 PM
mudflap91's Avatar
I looked at the wire and seen no breaks.Im going to order a fuel pump in the morning. And see if thats whats going on . How is the Walbro electric fuel pump ?
Old Nov 19, 2007 | 08:54 PM
longhungsilver's Avatar
i doubt its the fuel pump itself.. its going to be wires shorting sumwhere
mreagen
Oct 5, 2015 04:27 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
rmill05
Sep 27, 2015 01:43 PM
Rcbc92
Sep 26, 2015 03:00 PM
