efi conversion help - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-18-2008, 07:52 PM   #1 (permalink)
efi conversion help
Everything is pretty much complete. I have the efi dash harness, engine harness, fuel tank. This is all in an 85 4x4. It cranks and fires bit will only run for a second. I dont think its getting fuel through the injectors. It has fuel to the rail and the cold start. What could be my problem? Thanks!
mr2george is offline
Old 02-18-2008, 07:59 PM   #2 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
im assuming you have the AFM hooked up? And no air leaks?
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 02-18-2008, 08:37 PM   #3 (permalink)
Quote:
Yes the afm is hooked up. Doesn't seem to be any leaks
Old 02-19-2008, 10:59 AM   #4 (permalink)
superjoe83's Avatar
Send a message via AIM to superjoe83
make sure you have 12v to the single plug on the injector resister with the key on. Since its running on the cold start injector, this tells me that the fuel pump is working when cranking at least
__________________
- Joe
1984 SR5 4runner, 22re, 5-speed, chevy 63"s, rears up front custom pack, BBCS shocks, 2" BL, 5.29's, welded rear, Detroit in front, Longfields, IFS Rear, 39.5x13.50x15 IROK's, Marlin's High Steer, MC07 with stock cases, Marlin's cross member, tube bumper, Warn XD9000, Allied Beadlocks
1999 Taco 2.7 5-speed, LCE Header, Jardine 2.25 Cat-Back, 3" Downey Coilover, 33x13.5 Toyo MT's, ARB Bull Bar, Retrofitted Acura TL HID Projectors with 50W ballasts and 50W DL50 Philips 3900k bulbs
superjoe83 is offline
Old 02-19-2008, 06:27 PM   #5 (permalink)
I just checked the resistor with an ohmeter and got 12 volts. Anyone else have a clue what it could be? I don't think its getting an injector pulse.
Old 02-19-2008, 07:21 PM   #6 (permalink)
We checked the injector connector and got .01 volts. Then we checked the same wires at the ecu plug and got 12 volts. Any ideas? Maby some wires got cut somewhere in the harness.
Old 02-19-2008, 09:28 PM   #7 (permalink)
Send a message via AIM to dcg9381
Quote:
No that's the correct behavior.
The injectors are fired by pulsing them to ground. They're actually a single bank of injectors altough the ECU indicates two different banks.
Are you getting cranking RPM on the tach when hitting the starter?
Sure you have fuel pressure?
One way to test for injector trigger is to put a test light across the terminals of the injector connector. Crank the truck. You should see that light go on and off very fast - it might be best to use an LED test light.
ECU needs cranking RPM to know to trigger the injectors... i'd suspect that it's not getting cranking RPM indications from the ignitor if you have no tach deflection and no injector trigger.
__________________
http://www.22REturbo.net
dcg9381 is offline
Old 02-19-2008, 10:46 PM   #8 (permalink)
Ya i'm pretty sure i'm gettting fuel pressure it reaches the cold start and the rail ive cracked both lines. We checked to see if the tack works and it does it jumps up to about a 700 rpm's when it starts for a second.
Old 02-20-2008, 07:55 AM   #9 (permalink)
Check for the ground pulse, as I've indicated.
__________________
dcg9381 is offline
Old 02-20-2008, 10:44 AM   #10 (permalink)
ya theres definately no pulse through the injector plug we just checked it with a test light
Old 02-20-2008, 02:15 PM   #11 (permalink)
OK. You're checking across the terminals at the injector plug, with the injector unplugged, correct?
If so - that would indicate that your ECU isn't getting cranking RPM. If you have access to a FSM, I'd go through the "no fuel" diagnostic procedure - but what I'd be looking for is the signal out of the ignitor coming into the ECU that tells the ECU that the truck is cranking... I can probably detail out which pin that is if you need me to. The input is either a 12v or 5v square wave.. I forget which.
You can simulate cranking if you've got spare distributor. Just turn the truck "ON" connect the distributor and give it a spin. I've hooked mine up to an electric drill before to check tach and other operations.
__________________
dcg9381 is offline
Old 02-20-2008, 06:17 PM   #12 (permalink)
Ya if you could tell me which wire it is to check on the ignitor or ecu that would be great
Old 02-21-2008, 01:25 PM   #13 (permalink)
I found out we don't have power running from the harness that runs across the valve cover too the ingnitor.
Old 02-21-2008, 01:46 PM   #14 (permalink)
OK, resolve that issue and see what happens.. :-)
__________________
dcg9381 is offline
Old 02-21-2008, 06:22 PM   #15 (permalink)
Y would we not have power there though? What does this harness do it looks it ties into the injector harness from the coil. its three wires
Old 02-21-2008, 07:55 PM   #16 (permalink)
I don't understand the question.
The ignitor isn't passive (unpowered). It's job is to take the VR signal out of the distributor, translate it to a square wave and send it to the ECU. The ECU then makes decisions about timing and tells the ignitor when to fire the coil.
Here's a photo of how it works.. Just assume the megasquirt in the photo is the stock ECU:
http://lakebox.dnsalias.com/photos/1...igncontrol.htm
__________________
dcg9381 is offline
Old 02-21-2008, 09:27 PM   #17 (permalink)
ok well there seems to be 3 plugs on the ignitor, one smaller one, and two bigger ones, one of the bigger ones goes to the distributor, the smaller one plugs into the harness right by the ignitor, the other one that doesn't have power thats supposed to runs across the valve cover and ties into the harness under the upper intake plenum. I checked this plug on a 4 runner and it had power to 2 of the three terminals with the key on. Mine has no power at any of them with the key on.
Old 02-22-2008, 08:05 AM   #18 (permalink)
You really need a wiring diagram from the right year of truck. You can't just hook up a 12v probe or volt meter to various wires and decide what needs power, especially since the signal wires generate 12v square waves (which can show as 12v or 0v depending cranking / engine position).
My advice is to get the FSM, map out the wires to the ignitor - there should only be one "power" wire to a switched ignition source.
__________________
dcg9381 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Honda CBX 1100: Need info on EFI conversion Neighborcat Off Topic Talk 0 06-19-2007 02:57 AM
EFI swap 22r truck to 88 4runner efi parts yotanothing 86-95 Trucks & 4Runners 2 02-26-2007 05:40 PM
Superjoe's EFI conversion thread superjoe83 95.5-2004 Tacomas & 96-2002 4Runners 15 07-08-2005 12:19 AM
EFI conversion on Landcruiser Yoda Off Topic Talk 2 07-23-2002 08:53 PM
EFI conversion in progress Yoda 95.5-2004 Tacomas & 96-2002 4Runners 1 06-23-2002 10:39 AM
2009 InternetBrands, Inc.
