ECM Failures
ECM Failures
Has anyone ever replaced their ECM? How often do they fail? Is it likely to fail and have zero codes generated, or visversa, tons of codes all over.
In 25 years of working on Toyota's I've never heard of an ECM failing all by itself. It usually takes an electrical mistake by someone that causes it to fry.
The CEL will be inop if the EFI relay has failed. Or the bulb is burned out. Or a wiring issue. The FSM has a trouble shooting section on the ECM that will take you through tests to determine what the problem is. Go through that before replacing an expensive ECM.
I have had 2 ECU's with holes rotted in the sides of them and full of salt and water. They work fine. The ECU's in these trucks are very dumb and do not have much in them. Like was said, human error blowing them (still hard to do as most of it is protected with the efi fuse) or 1 in 10 million component failure.
_Nicco_
09-21-2015 03:06 PM
