dual tcase
Old 10-06-2009, 09:52 PM
blueyota's Avatar
dual tcase
Hello all thanks for reading ...I am just wondering ...well i have a dual tcase installed in my 91 pickup and is leaking oil a bit and im wanting to pull my motor for a rebuild can i pull it out just like the standard way all together or is it going to be to heavy and awkward and have to come out seperated im just asking before i get there and realize it wont come out as one ....thanks
Old 10-06-2009, 09:55 PM
iamsuperbleeder's Avatar
with dual t-cases? yeah you're probably better off dropping it out from under the truck, lol
hell even a stock setup with 1 t-case, I'd rather pull it out from under the truck, lol
where's it leaking from? might not have to pull it all the way out
Old 10-06-2009, 10:02 PM
blueyota's Avatar
its leaking from one of the main gaskets around the top ...i figured i would droping it from under but i thought i might give it a shot as a whole if i could ...lol
Old 10-06-2009, 10:04 PM
89silverpu's Avatar
It'd be way easier to drop the dual case setup and transmission together and then take the motor out. The transmission dual t-case set up would most likely be too long to even be able to get an angle to pull the motor out with it all attached. Just get or borrow a tranny jack, it makes droppin/stabbing a dual t-case transmission setup way easier
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
hiluxinargentina
09-30-2015 05:51 PM
JookUpVandetti
09-30-2015 08:58 AM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: dual tcase
