dry metallic scraping noise from the rear end, quieter when braking
Old 04-18-2008, 02:19 PM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
as the title says, I have a dry metallic scraping noise somewhere on the rear axle of my truck. kind of sickening, actually. but yeah, it quiets down (doesn't disappear) quite a bit when I brake. JUST got it back from my mechanic. he said it all looked good. wheel bearings, rear diff, rotors.
Any input would be appreciated. I really don't want to wait for something to break before I figure it out...
thanks guys!
Old 04-18-2008, 04:29 PM
MonsterMaxx's Avatar
Pull the drums off, I'm betting you have parts loose in there.
Old 04-18-2008, 07:18 PM
just a 22re's Avatar
is your e-brake on???
Old 04-18-2008, 08:14 PM
possible that its frozen as it has done that to me before. I will disassemble that and clean it all up soon anyways, as I want it to be 100%, but I also wanna eliminate anything that could rack up some serious $$ in repair bills. def a good thought though!
Old 04-19-2008, 09:57 AM
Coroles's Avatar
I have a similar sound from the rear end of my truck. I don't think that mine has to do with the brakes do to the fact that I just rebuilt them, turned rotors, new shoes and what not. My wheel bearings seem to be good but I still plan on taking it apart to try to find the problem...the lube in the rear end looks gross anyway so it will need changed regardless. The only thing that I noticed that it could possibly be is the back plate rubbing on the drum, backing plate is a little bent.
Old 04-19-2008, 10:33 AM
Noltz's Avatar
I'm guessing rust on the drum lip scraping the backing plate.
Old 04-20-2008, 09:27 AM
isaac338's Avatar
check to make sure your rear brakes are adjusted properly - maybe one side is dragging more than the other or something.
my truck drags on the rear right and it has symptoms exactly like that.
Old 04-20-2008, 09:30 AM
dirtoyboy's Avatar
or a bent backing plate...only way to find out is to start taking things apart...or jack it up and start turning the wheels
06-01-2021 01:51 PM
Road Bull
10-10-2015 04:55 PM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: dry metallic scraping noise from the rear end, quieter when braking
