disable steering lock in a first gen?
My first gens steering wheel is locked and I cant turn the key. This has been a problem that has just gotten worse. At first I would have to turn the wheel side to side to get the key to turn ,but now the key will not turn. I think the lock will not disingadge . How can I disable the steering lock? I dont want to tear up the ignition. Thanks Corbit.
push the little button on top of the column while jiggling the wheel.....
then do the roger brown mod http://www.4crawler.com/4x4/CheapTri...yRemovalButton
The little button wont go down. The key can be removed , and when put back in feels like it is hitting all the tumblers. It feels like the wheel lock is stuck. How can I disable the wheel lock ?
Rodger , do you mean the little pin on the ignition that is in line with the wiper switch ,or are you talking about something below the switch. I see a cap almost the size of a quarter below the ignition ,if this is it how do I remove the cap. I am almost ready to get my big hammer and fix it. Thanks for your input , David.
Roger ,Thanks for the tip. I pushed the little pin on the ignition while turning the key and prying the ignition and it popped right out. I'll have to get it re keyed. Thanks David.
06-01-2021 01:51 PM
theking11863
03-19-2016 09:36 PM
