Direct Bolt-On? Transmission+Transfer
Old 04-12-2010, 12:44 PM
Murdock's Avatar
Newb question...I have a 93 ex-cab 22re, G58 trans, VF1A transfer...would a W56 trans and RF1A transfer case from a 88 22re ex-cab bolt directly into mine? I haven't checked out the parts yet but i believe the 88 parts are top shifts...any alignment issuses? I was originally just gonna get the stock aisin locking hubs from the 88 but if i can get the W56 and the gear driven X-case too why not... Any help would be greatly appreciated.
Old 04-12-2010, 03:54 PM
Flash319's Avatar
They all bolt up fine. 3 things that you have to deal with.
1. Speedo (mechanical or electric) All the gear cases are mechanical as far as I know. You can get a converter from Marlin Crawler, thats what I did when I went gear.
2. Shifter location. You may have to cut the floor a few inches.
3. Drive shaft flange bolts come in 2 sizes. You may have to drill the flangs (1-2mm) holes on the driveshaft or just put smaller bolts in.
Old 04-12-2010, 05:03 PM
Murdock's Avatar
Thanks Flash...
1. Didn't really know about the speedo issue...will have to look into that.
2. Not to worried about hacking the floor up...I just hope I cut only once.
3. The lengths of the stock driveshafts (front and rear) should be ok then to mate up?
thanks again
Old 04-12-2010, 06:41 PM
Flash319's Avatar
The lengths are fine just the older trans/xcases had smaller holes in the yokes by a few mm. Not a big deal as they are centered on a lip inside. You just have to get a bolt that fits or drill a little bit.
Old 04-14-2010, 10:46 AM
Murdock's Avatar
checked out the 88...the trans and xcase were missing the shifters!! I guess someone just needed the shifters only...Anyone know if G58/VF1A shifters will fit on the w56/RF1A...i doubt it though. Would really save the time of hunting down these parts
Old 04-14-2010, 04:08 PM
Levis Pennae's Avatar
Don't want to make a new thread.
Would an R151F transmission bolt in place of a W56 transmission?
Old 04-15-2010, 02:03 PM
Murdock's Avatar
I would think so but I'm no expert....seeing that they both mate to a RF1A xcase and 22r block....I could be wrong
Old 04-15-2010, 06:00 PM
I figured it would mate up at both ends, I'm just not sure about the cross member.
Old 04-16-2010, 03:53 PM
Murdock's Avatar
Yeah I was thinking about that too for my swap...see if you can get the cross member from the R1F1
Old 04-23-2010, 05:20 PM
Murdock's Avatar
question: If I did this swap, what year clucth kit would I have to look for and why?
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Direct Bolt-On? Transmission+Transfer
