did the ISR mod and deckplate today
With PVC pipe it will also depend on what type you buy schedule 40 or schedule 90 pipe. Stuff that is cheaper and thinner that is used for down spouts or more expensive and thicker stuff you use for septic systems. That one picture looks like a 120 degree bend not a 90 degree bend.
#25
The pipe I used is the thicker stuff meant for electrical. It was a 90 that I cut to fit. It works well so far although I would probably use one size smaller diameter next time. Knowing what I know how lol.
#26
I put an Allen Johnson snorkel on my 94 p/u about 7 years ago, works great! I used 3" PVC, I will get some picks up when I get a chance, my brother is driving it right know. I am currentley working on one for my 3.0 4runner, I have already taken off the silencers and I got my brass fittings from Harbour Freight, 3 for 2.99$ I will post some pics when I finally finish it.
#27
is it possible to do a deckplate with a snorkel....im looking at doing the deck plate soon...then down the road getting a snorkel...pull the deckplate out for daily driving and plug it for offroad underwater stuff...
#28
So... yeup, you can do the deckplate now and add a snorkel later, but when you add the snorkel, you'll just want to put the deckplate in and keep it there.
#29
the problem being is im doing the deckplte on the 3.0....so i know theres a diffrence in the airbox....so i think i might just wing it and see where it goes....
#30
Check the Tech section here, I'm pretty sure there's a writeup for the 3.0.
#33
cansomeone tell me what is on the rightside of the air box..itlooks like it wouldbe a good location for the deckplate, if i couldjsut remove it...any help on if it can be removed
#37
TheBFA
02-15-2020 06:55 AM
Toys4parts
09-26-2015 01:56 PM
