dents in the bed
Old 02-24-2009, 07:26 AM
DupermanDave's Avatar
dents in the bed
I have a dent in the back quarter of my bed. It's a big (size of a frisbee) dent, but it doesnt have any creases or bends.
I'd get a picture for you all, but it's a slight bend and I would need some good lighting to let you guys see the foll scope of the bend. Even then, truck needs a good washing before you can see the bend.
My question is can I go under the bed and with a rubber mallet tap these dents out?
I've gone under the truck before and tried pushing them out, but i need to pound them out. What's the best way to do this?
The reason I'm worried about this section is because I want to get some JRU (Jeep Rescue Unit) stickers from http://www.jamesdeancreations.com/logos.htm#yotatech and I wanted this area to be dent free, otherwise I'd run into trouble placing the decal there.
Old 02-24-2009, 08:26 AM
algranger's Avatar
should be able to bang it if you can't push it but you might loose some paint
Old 02-24-2009, 08:35 AM
Was actually going to spray paint the whole thing anyway. No worries there.
Old 02-24-2009, 08:57 AM
algranger's Avatar
Oh cool. Well it's worth a try. If all else fails, whip out the bondo
Old 02-24-2009, 09:00 AM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Or you can buy 1 of those big suction cup dent pullers. They are pretty cheap, and just 'bout every autoparts house carries 'em.
Old 02-24-2009, 09:17 AM
Thought about that, but that's almost the price of a gallon of bondo mix. Bondo works, and this dent puller might not.
Old 02-24-2009, 09:21 AM
Flash319's Avatar
If you can't get to the back of it and push it out then what I do is this:
Weld a washer to the dent and then use a slide hammer or equivlent and bang it out. Grind the washer off.
Old 02-24-2009, 09:24 AM
scuba's Avatar
Did someone say my name
Old 02-24-2009, 05:13 PM
This is the method i've seen done to deeper dents, but I don't have a slide hammer, a grinder, or a welder. It's the method I'd like to learn to do, though.
Living in an apartment building, I have no place to store a grinder and a welder.
Old 02-24-2009, 05:16 PM
bipolarandproud's Avatar
yep ........I've been known to put dents in A bed .haha
Old 02-25-2009, 04:09 AM
djkeev's Avatar
Hi,
Cheap, easy, fast, effective
If you can get behind the dent and it's in between the interior and exterior panels, purchase a cheap basketball or soccer ball, deflate it and shove it up behind the dent.
Now inflate the ball until the dent is pushed out.
Viola! Paintless, putty less dent removal!
Good Luck
Dave
Old 02-25-2009, 04:55 AM
Originally Posted by djkeev
Hi,
Good Luck
Dave
That's pretty nifty. I might actually have to try that, because it is on a panel that has some space between it and the frame.
Old 02-25-2009, 05:03 AM
srozell's Avatar
Hi,
Good Luck
Dave
I may be cheap, easy, fast and effective, but I'll take exception to anyone trying to do that with MY balls.
Old 02-25-2009, 06:16 AM
littlecommando's Avatar
Hi,
Good Luck
Dave
if you do this, take a video
i want to see that work!
I8URSVT
03-02-2021 06:23 AM
ToyotaMD
11-09-2015 11:53 AM
Brodetski
09-30-2015 11:50 PM
87SR5justin
09-29-2015 02:50 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: dents in the bed
