The csi issue
Old 02-24-2012, 05:48 PM
my 75 toyota's Avatar
The csi issue
where can i find a FMS for a 88 pickup 22re so can look at the wiring diagram for the csi and time switch
Old 02-24-2012, 05:50 PM
My Hanyes book does not lay this circiut out for me
Old 02-24-2012, 05:53 PM
Fossilized
Staff
dropzone's Avatar
http://ncttora.com/fsm/index.html
Old 02-24-2012, 06:08 PM
Ok i got this one and it say the green wire between the csi and the timer swich and the stj terminal of the ecm and the other one shows only between csi and timer i am confused
Old 02-24-2012, 08:34 PM
wyoming9's Avatar
Red face
Just what are you trying to figure out??
Just what do you need to know??
Old 02-25-2012, 04:46 AM
well on the correct wiring for the cold start circuit. When i got this all those wires had been removed so . In the Haynes repair manual it says the green wire goes from the timer switch to the injector only. And in the FMS i downloaded from a prev post that is nice bye the way it says the green wire goes from timer to the injector and also the STJ terminal of ecm.
Old 02-25-2012, 05:49 AM
Bassmastry101's Avatar
So if I understand correct you are wiring up everything and want to know which diagram is correct? Stick with the FSM.
I think the cold start injector only comes on when the ignition switch is on start.
According to the diagram, the blue wire goes into the CSI and to the time switch with a Green wire. Then back out of the time switch with a blue wire to the ECU 1-7(STJ).
Old 02-25-2012, 09:44 AM
jeetS's Avatar
both the CSI and time switch have power when the key is in the START position.
The time switch provides the ground for the CSI if the water is cool enough. If its warm then it does not provide ground and the CSI cannot fire.
The time switch has a heater element inside it that receives power when cranking that heats up the sensor after a set amount of "time". This prevents the CSI from dumping fuel in forever if you're cranking it for a long time without it starting. Thus preventing flooding.
Old 03-01-2012, 05:44 PM
Thanks jeetS now that is the answer i am looking for
Old 03-02-2012, 04:14 PM
jeetS's Avatar
hey no problem
bigjstang
08-25-2021 12:41 AM
nvdesertrunner
05-11-2020 08:18 PM
crammit442
7
11-29-2017 12:30 PM
raptor510
08-19-2015 02:15 PM
rjtrials
08-06-2015 07:25 PM
Quick Reply: The csi issue
