A couple questions please
Old 11-16-2012, 06:59 PM
blu911's Avatar
Talking A couple questions please
When i install the new engine (22RE) in my 1988 4X4 single cab pickup...
Question 1) is it easier to install the engine and trans bolted together (One Piece) or engine then the trans?
I'm adding A/C to my truck that came from factory with no A/C
Question 2) I have NEW Compressor, NEW Evap, New Condenser, NEW Dryer... How much Oil should I put in compressor before I charge it? I can't find the capacity anywhere...
Question 3) Do I need to change or add any wire harness for the A/C? again my truck came from factory with no A/C...
THANK YOU SO MUCH!
Old 11-16-2012, 07:06 PM
moutainman4life's Avatar
i found it easyer to bolt the motor and tranny together before droping them in i ust to drive a two wheel drive and had to switch the motor to my 4x4 every weekend tell i could afford a new motor
Old 11-16-2012, 07:07 PM
rattlewagon's Avatar
Cant help on the ac, but put the engine in first, then the tranny. Use a 3' extension and a swivel to get to the top 2 tranny bolts.
Old 11-16-2012, 07:08 PM
but i dont know about the a/c never added it
Old 11-16-2012, 07:15 PM
blu911's Avatar
Thanks Mountian Man...... But every weekend? Wow
Old 11-16-2012, 07:17 PM
blu911's Avatar
Thanks Rattlewagon :-)
Old 11-16-2012, 07:26 PM
yep every weekend for like 6 months i try'd leaving the trannys in but it was easyer to line it all up on the ground then fighting it in every time
Old 11-16-2012, 07:29 PM
blu911's Avatar
(((yep every weekend for like 6 months i try'd leaving the trannys in but it was easyer to line it all up on the ground then fighting it in every time ))) Your my Hero!
Sleaker
08-26-2020 06:03 AM
TJWilly
07-31-2015 02:05 PM
DrZero
18
07-24-2015 11:31 PM
icentropy
07-14-2015 10:23 AM
Quick Reply: A couple questions please
