Cold start switch
It varies by make, model, year. 89462-200 is not a part number (not enough digits). Instead of "I keep coming up with ...", if you tell us how you found the part numbers it makes it easier for us to figure out what you're trying to do.
Cold Start Injector Time Switches go for about $140-$160 at places like http://www.toyotapartszone.com/ and http://www.toyotapartsoverstock.com/
Just out of curiosity, how did you determine that was the part you needed?
It was 8964220040, typo missed the last 2 numbers my bad. I figured out they changed half way through 88 so I had the dealer my vin and got the right number and ordered online from newnan toyota for around 140. Saw on another forum that either part will work and alot of people in older toyotas run the newer one to help with long cranks. And I figured out mine was bad by pulling the injector when it was cold and getting no fuel. And running the fuel problem tests on 4crawlers sight
Johntom240
7
07-13-2015 12:18 AM
