cold start issues
Old 02-24-2012, 11:53 AM
toastyjosh's Avatar
cold start issues
So truck will not start very well when cold. i just got this truck. So It will crank and thenpop like it is going to start, if I hit the gas in the right way it will fire but not allways. So I usually will try it if it does not fire i will spray eather in the manafold and it fires right up.
I did check the cold start injector, pulled it out and cleaned the crap out of it, did not change anything, so I tryed to start it with the injector out to see if any fuel came out and none did.
So what next? It is a 1988 22re 5 speed
Thanks!
Old 02-24-2012, 01:50 PM
BMcEL's Avatar
Test the cold start time switch.
Old 02-24-2012, 07:19 PM
toastyjosh's Avatar
Where is that? I can not find it. the chiltons manual is no help.
Thanks
Old 02-24-2012, 07:25 PM
BMcEL's Avatar
Link to factory service manuals is in my signature.
Old 02-25-2012, 02:36 AM
mldave's Avatar
under the T-stat housing,the plug on the left.
Old 02-25-2012, 07:47 AM
toastyjosh's Avatar
Thanks Dude!!!!
Great pic!
Old 02-25-2012, 12:47 PM
toastyjosh's Avatar
Holy crap ITs a 122 bucks at autozone for that switch!
Old 02-25-2012, 01:47 PM
mldave's Avatar
Get the number off the part and hit the wrecking yards or post on the forum in the parts wanted section.They have different numbers for different years.
Old 02-26-2012, 10:44 AM
imlearjet's Avatar
3.0 cold start issue
Having same issue on my 3.0. I just replaced the ks wire and while disassembling found the sensors on the water bypass disconnected. I have 3 sensors on the bypass. I need to confirm that the far right, black plug goes to the fuel injector wire harness for the cold start injector;
the center one is broken and needs to be replaced: I believe this is the ECT sensor that plugs into the 2 pin grey connector from the wire harness on the driverside wire harness?
There is a single blade grey connector on the far left(driverside) that is for the temp gauge?
Thanks in advance for the help.
Old 02-26-2012, 12:09 PM
paintthetown's Avatar
There are 3 different guys that sell used Toyota parts on eBay. Make sure that you have the correct part number for any parts before you make the purchase. I've bought parts from all 3 of them without a single problem.
Old 02-27-2012, 11:23 AM
BMcEL's Avatar
Did you test it?
Old 02-27-2012, 02:23 PM
angrybob's Avatar
This link will probably help you test it.
Old 02-27-2012, 02:42 PM
toastyjosh's Avatar
This link will probably help you test it. angrybob
Thanks for the link! So I have kind of a dumb question,
when testing the STA to the STJ would I use the red probe on the meter on the STA and the black to the STJ??
Thanks
Old 02-27-2012, 02:53 PM
toastyjosh's Avatar
here we go!
http://www.ncttora.com/fsm/1993/engine/39colds.pdf
Old 02-27-2012, 09:06 PM
stanz's Avatar
If you follow this, you'll have your answers: http://www.youtube.com/watch?v=Ee9SC0K0nK8
Old 03-04-2012, 09:04 PM
StewsRunner's Avatar
Hey I have a similar starting issue, actually it's the opposite. In the morning when it is below freezing my 91 3vze starts right up and sounds good. once it's been sitting in the sun all day like at work or school it has a hard time starting. the hotter the outside temp, the harder it is to start. it cranks and cranks and cranks, it's turning over fine but will not catch. it's getting fuel and spark. . . it did not start until the weather changed so i was thinking maybe the cld start injector (i read that those get stuck open?) i am also thinking the ECT sensor or maybe the cable running from the battery to the starter. I will be testing all of these this coming friday so any tips or advice would be much appreciated. -Stu
Old 03-04-2012, 09:35 PM
stanz's Avatar
I'd look at the AFM as well. If you've got cranking, fuel and spark it sounds like air is the only other variable. Be sure to check out all of the obvious stuff too -- cap, rotor, wires, plugs while you're at it.
Old 03-04-2012, 09:44 PM
yea the pick up coil, ignitor and cap all check out. . . new plugs, wires need to be changed soon. . . everything that i think of i have to take the outside temp into consideration.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
coryc85
09-09-2015 06:24 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: cold start issues
