coil/igniter- test help needed
Old 12-08-2007, 05:53 AM
"pete f passed away quietly in his sleep on July 13, 2008
pete f's Avatar
My 89 pick-up 3.0vze still won't fire. I have two threads going now. So far I have replaced my Distributor/wires and coil. I have voltage @ the black/ red wire on both coil and igniter. The black /white wire on the coil would not light my test light and I have no continuity between coil and igniter on the black / white . If I have voltage with the key on does this mean the ecm is okay. I have no engine check light now when I turn the key on. I jumped the TE 1 and E1 and still no check engine light.
Old 12-08-2007, 10:54 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Check the EFI relay and fuse. You may have blown one or both somehow. Or, may have just been going all along. Hopefully, it's not your ECM.
Old 12-08-2007, 11:53 AM
pete f's Avatar
I'll check the fuses. Went to the junk yard and got another igniter but still no luck yet
Old 12-08-2007, 03:25 PM
pete f's Avatar
The round efi may be blown tried testing forcontinuity but it has four prongs . I'm not sure how to test it.
Old 12-08-2007, 04:31 PM
thook's Avatar
Testing....one, two, three....testing
http://personal.utulsa.edu/~nathan-b...95efimainr.pdf
Old 12-08-2007, 08:03 PM
pete f's Avatar
I will test in the morning .thanks Matt
Old 12-09-2007, 01:14 AM
thook's Avatar
"Matthew"
You're welcome.
Old 12-09-2007, 02:56 AM
pete f's Avatar
"Matthew"
You're welcome.
I'm sorry about that Matthew.I was going to go deer hunting this a.m.but I'm pulling that fuse and testing 1 2 3 .
Old 12-09-2007, 01:26 PM
pete f's Avatar
Well I tested my round EFI fuse in the box on the passenger fender in engine compartment and thought it was bad . I bought a new one at the parts store and still no spark . Then a friend stopped by who is an electric whiz and we tested the old fuse and he said it looked good to him it passed all the test for continuity. Well I put the new fuse in . He helped me test for continuity on the black/white wire that goes from the igniter plug to the coil. The metal prongs in the plugs have continuity only on one side.So the only way it might work is that the plg has to lineup just right or no spark. I'm calling Toyota dealer tomorrow morning and ordering the new plugs.I'll keep you posted
Old 12-09-2007, 05:31 PM
Targetnut's Avatar
If the check engine light does not come on when the key is turned on or when the diagnostic terminal is jumped. It is usually a sign that the ECM is not "powering up" which would also result in a no-start condition.
It could be a problem with the check engine light circuit but that is unlikely
Old 12-09-2007, 05:52 PM
thook's Avatar
S'alright. Just hate being called Matt. Thanks.
After the experience I've recently had, Pete, I would test your ECM. The test is very simple......nothing to tear down to get to it....and it would help matters tremendously to be able to rule it out. If it is a problem, you could be running around the vehicle forever until you did rule it out. If it's fine... happy, happy....joy, joy.
http://personal.utulsa.edu/~nathan-b...e/102engin.pdf
Old 12-10-2007, 02:33 PM
thook's Avatar
Okay, found the thread quickly reaching the bottom of the page...
No continuity on that wire means no signal/current through it, either. This I'm sure you know. So, yeah....that must be fixed.
If the connectors themselves are good and it's just a break in the wire, you could perform a solder surgery on it. ?????
Old 12-10-2007, 03:36 PM
pete f's Avatar
I'm sure it is the metal prongs in the plugs. I gotta call the junkyard in a.m. to get the plugs. Yota dealer said I gotta buy a whole new harness.
Old 12-10-2007, 03:59 PM
TNRabbit's Avatar
Geez. pete! How many different threads are you gonna start on this?!??!
Old 12-10-2007, 04:47 PM
pete f's Avatar
My other thread www.yotatech/f1163-0-ecm-89pick-up-fsm-131904
Old 12-12-2007, 08:14 AM
dcg9381's Avatar
Pete, go through the steps outlined about - there is no better trouble shooting procedure than the FSM.
In my experience, it's usually the pickup on the distributor, but if you go throught the FSM procedure, we'll be much better equipped to help.
Old 12-12-2007, 11:02 AM
pete f's Avatar
You are right I think I found my problem . My EFI main relay failed continuity. I ordered one today. Last week when I got code 12(distributor) and 51(Throttle position sensor) are all connected on the current line. I think I'm on the right track now.Thanks to the FSM.
bigjstang
08-25-2021 12:41 AM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
zd92655
07-05-2015 04:25 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: coil/igniter- test help needed
